Astra MK3 Wishbones bolts
Results 1 to 12 of 12
Thread: Astra MK3 Wishbones bolts
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    I need help about the front wishbones bolts dimensions
    I have loose mine some at the time of car rebuilding ... :-(
    EPC says
    FRONT BOLTS (horizontal bushes)
    No 13 M12 x 90 Hex Bolt = 11 091 643
    It seems correct ... the hole of the bushes sleeve is a little more that 12 mm
    REAR BOLTS (vertical bushes)
    No 14 M12 x 90 Hex Bolt = 11 092 273
    It does not seem correct cause the hole of the metal sleeve is about 16 mm
    and the two additional sleeves reduce it to about 15 mm more or less
    I think a 12 mm bolt will play too much ...
    Astra MK3 C20LET Work in Progress
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Re: Astra MK3 Wishbones bolts
    I vaguely remember both my front and rear bolts being very similar when I did the wishbones on my MK3.
    In fact, I ordered some new ones from Vaux, took the old ones on one side out very carefully so I could match them up, put the new ones in and went to do the other side only to find the two were in the other way round from the wishbone I'd just done lol.
    I think one bolt has a slightly pointier tip than the other - the sleeves were fairly nice and tight on mine up to the bolt - certainly not loose enough for the bolt to rattle around.
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    I suppose that the vertical bush is fixed to the chassis in position by the sleeves??
    But i cannot understand the reason why ...
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    Anyone could tell me any information about that?
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    up...................
    MIGClub Member Turbostevo's Avatar
    Jan 2011
    Chesterfield, derbyshire
    Saabastra/E36328/bora/147
    Give me a week and I'll have you an answer buddy.
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    Ok thanks
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    up..........................................
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    anyone?
    Jan 2012
    swindon wilts
    astra mk3 20ser sleeper
    if u have other transport go to your local scrapyard and take out from a scrapper lol
    Apr 2008
    Birmingham
    1.7XDTL ASTRA
    From what I remember when I replaced my wishbones (1995 Mk3), the two bolts were 12mm diameter (of similar lengths), but the vertical and horizontal bolts had a different thread pitch, hence the different EPC part numbers. They are not interchangeable. The bolts were a snug fit in the (single) tubular shims, one per bush. I cannot explain why you need to use two shims per bush.
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    Quote Originally Posted by AndyHock View Post
    Ok thanks
    This is exactly the last issue
    "why you need to use two shims per bush"
