i've dropped a c20xe from a 92 calibra running Motronic 2.5 into my mini
having a problem with the fuel pump priming when the hazzards are on
then on trouble shooting if i put the tester from the ecu casing to the body i'm getting 3.3v....
which inturn put a wire from the ecu casing to an earth the fuel pump relays click like mad.....take the wire away and all is fine......
should the ecu be earthed or kept away from metal...???
