Can I remove this part (Cav/Cali 4x4)
Results 1 to 6 of 6
Thread: Can I remove this part (Cav/Cali 4x4)
    Sep 2004
    Nottingham M1 J26
    911. Loves: Dirty sluts.
    I'm using a Calibra 4x4 rear 5-stud setup on my FWD Calibra. So I've removed the diff and shafts as they aren't needed. Now on the rear of the hubs there is a dished piece of metal, with a large nut in the middle. This is what the rear shafts bolted to.
    Can it be removed? Or does it support/tension the wheel bearing?
    Sep 2009
    Isle of lewis
    Cavalier turbo, mk2 golf
    Re: Can I remove this part (Cav/Cali 4x4)
    cant remove that mate, the 2wd ones normally came with a plastic cap , the flanges hold it all together
    Sep 2004
    Nottingham M1 J26
    Quote Originally Posted by Cavalier-C20LET View Post
    Thought so pal. I'll stick the cap on it from my 2WD 4-stud setup! Cheers
    rc
    rc is online now
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    the rear bearings more like front wheel bearings than the normal rear type, with a hub nut and washer, and the washer just happens to have the driveshaft bolt holes in them too, thats why the 2wd ones have the flange too.
    Sep 2004
    Nottingham M1 J26
    Quote Originally Posted by rc View Post
    Cheers dude
    So will my 2wd cover fit on the 4wd washer?
    rc
    rc is online now
    Jan 2007
    359.9bhp astra
    yep should do.
