Cv joint/ wheel bearing! C20XE Corsa
Results 1 to 9 of 9
Thread: Cv joint/ wheel bearing! C20XE Corsa
    Jan 2012
    Barnsley
    Corsa B C20XE
    Hey guys quick one for you!
    Garage has fitted a cv gaitor to my nearside cv joint (they might have changed te cv joint aswell i need to check the paperwork)
    When setting off now i'm hearing like a creaking noise just as i set off and then it stops straight away, its coming from the nearside front corner i think.
    Any ideas what it may be?
    Wheel bearing was loose as well so they've tightened that back up?
    Thanks in advance guys
    Connor
    Aug 2009
    bristol
    corsa b arden blue
    Re: Cv joint/ wheel bearing! C20XE Corsa
    On a front wheel bearing it is jot adjustable so they wouldnt have been able to tighten it
    sounds like more of a brake binding issue
    Jan 2012
    Barnsley
    Corsa B C20XE
    Its got Cavalier discs n calipers on so i'll price them up.
    Cheers matey
    Jul 2009
    Hants/Lincs
    I would identify the issue first to be sure rather than pricing up parts you may not need.
    Jan 2012
    Barnsley
    Corsa B C20XE
    I agree but brakes havent been changed for a year so probs worthwhile anyway
    Jul 2009
    Hants/Lincs
    I would just jack the front up take the wheel off and have a look/wiggle rotate etc should be obvious
    Jan 2012
    Barnsley
    Corsa B C20XE
    For brakes??
    Jul 2009
    Hants/Lincs
    For a possible cv joint/wheel bearing problem as per your title
    Jan 2012
    Barnsley
    Corsa B C20XE
    My bad!
