corsa b20xe brakes?
I currently have rear drums 1.4sri and 2.0litre front discs and calipers braking doesn't fill me with confidence lmao thought it would be better than it is any ideas? Cheers
Moderator
Re: corsa b20xe brakes?
Did you bleed the system?
Are the bleed nipples facing upwards on the calipers?
Are the discs and pads worn?
I bought the car with this setup so I haven't bled the system because fluid is full and ive no indication of air in the system pedal feels fine just feels weak ill check the bleed nipples but I'm sure the calipers are fine.wear is not to bad plenty on pads:-) ive never owned a normal corsa or one this quick so don't have anything to compare it too
