Is it a good idea to fit an electric sterring column on a corsa b with a C20xe engine???
Mines got one.
if you need the room in the bay then yeah why not, not sure how hard they are to fit though.
Vectra B Estate 2.2
Vectra B Saloon 2.6
do any body know how to wire the epas?
Has your Corsa got the epas from the factory? If it has all you need to do is wire in the rev counter, and the electric speedo drive from a 1.4 8v Corsa.
NO it is not have the epas from the factory I have to wire it.
Iv took mine out cuz it kept going wrong, theyre prone to being faulty, theres a torque setting on them or something. Iv just fitted a normal column & its fine
