Brake pedal quite soft
Results 1 to 5 of 5
Thread: Brake pedal quite soft
    MIGClub Member Corsa_LET's Avatar
    Sep 2011
    Nottingham
    Astra z20let sleeper
    My brake pedal on my corsa has a lot of travel before it actually does anything, once it reaches a point the brakes are good but want to bring the pedal up a bit. It has 308's fitted with the standard servo & no braided hoses. Would braided hoses bring it back up or have they possibly not been bled properly?
    Dec 2005
    Aldershot hampshire
    Agila c20let in making
    Re: Brake pedal quite soft
    Problem you have with bigger brakes on a standard Corsa servo, I'd go with Astra gte 256 brakes then the pedal will feel better.
    Save the trees, wipe your ass with a owl!
    Sep 2011
    Nottingham
    I presume i'll need the calipers to suit aswell will i? Was thinking of downgrading to 280 or 288 as i want 16" wheels but cant get them over 308's!
    MIGClub Member -Jim-'s Avatar
    Jan 2012
    Derbyshire
    Z20LET Corsa C SRi
    Quote Originally Posted by Corsa_LET View Post
    308s fit over most 16" wheels
    And braided hoses will give you better pedal feel.
    Probably needs bleeding, you still using drum rears?
    Im using 308s front and 264mm rears on standard corsa c servo no problems and fitting 322 astra vxrs in feb
    Maybe could use a corsa c servo?
    Aug 2010
    Amsterdam
    5-door Astra MK2 C20XE
    Been told 288's will not even work well on the standard MC. Got 288's myself on my Astra MK2 with 22,2mm MC and braided hoses and that works really well I have to say... Got non ABS by the way.
    You may get better results with a different MC, have you got a clue what diameter the one you have now is? It's usually printed at the nose right under it.... You probably need a mirror or camera to see it...
