corsa c speedo how does it work with engine conversion?
Results 1 to 10 of 10
Thread: corsa c speedo how does it work with engine conversion?
    Mar 2010
    mk4 astra c20let
    just wondered where the corsa c gets its speedo feed from and how do people go about getting the speedo to work with engine conversions? my old mk4 astra was easy as just kept the old ecu to run the abs system and the speedo remained working. as far as i know most corsas dont have abs so how do you get the speedo working?? cheers
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Re: corsa c speedo how does it work with engine conversion?
    I guess it's either got a wheel sensor on one of the fronts or there's a sender that screws in to the 'box.
    They're there, in their room.
    Mar 2010
    mk4 astra c20let
    yeah thats what i was thinking..do u reckon even a non abs car might use a single wheel speed sensor? im just thinking if the lesser models use speedo cable then the f23 box doesnt have a cable outlet and the speedo isnt gonna work!
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    My MK4 Astra is non-ABS but uses an ABS hub and amplifier for the VSS.
    Mar 2010
    mk4 astra c20let
    Quote Originally Posted by Dom View Post
    ahh i didnt know that i thought they were cable! would be nice if corsa c was the same! cheers
    MIGWeb Moderator
    Midlands
    Nowt
    Corsa C uses same system as the Mk4 Astra, i.e from the ABS ring.
    Mar 2010
    mk4 astra c20let
    what about the lesser models without ABS? do they have one sensor purely for the speedo? cheers
    Nov 2006
    Newcastle (ish)
    Cavalier 1.8 LS
    ABS sensor on the C's and a speedo box sensor on the B's.
    "Stick your head in the microwave and get yourself a tan" - Weird Al - Dare to be Stupid
    MIGClub Member -Jim-'s Avatar
    Jan 2012
    Derbyshire
    Z20LET Corsa C SRi
    This
    Abs ring is the way 99% of the zle* converted c's go
    Although mines usin mk4 gsi hubs, so i made a loom out of 2 old corsa c abs sensors and astra abs plugs, so clips into hub and into standard corsa abs wiring!
    Nov 2011
    my 1.2 corsa C runs speedo from a hub ring. still works with a V6 shoved in the front! :-)
