corsa b how do i remove the speedo clear plastic cover
how do i remove the clear plastic which covers the speedo to fit chrome rings, i removed the cover via the 4 clips but the larger rings wont fit from behind i need to remove the front clear plastic cover but it seems bonded and brittle, any easy way of removing it
Re: corsa b how do i remove the speedo clear plastic cover
I to would like to no this
done it you have to be very careful and slowly brak the plastic welds best to use a blade, been told warming the plastic with a hair dryer helps
Ah ok ill give that a try then thanks
