Hi all
Been having an ongoin issue with my cdti 150 now for ages that i cant find the cause off This problem started when i had water contaminated fuel put in the car! I drained the tank! cleaned the filters ect and all seems ok till the next day i noticed the car kept goin into limp mode whilst driving!! I found that if i re started the car then it would be back to normal instantly untill it did the same thing again 10 mins later!
Whats seems od is the car never fails like this when driving harder and only when cruising And also it resolves itself as soon as i restart the car! Ive had the car tested on tech 2 with no codes of faults showing! Vauxhall have just suggested all i can do is guess parts to change but have said they think like me its fuel related as it started when the bad fuel went in... Im not sure were to start so thought id ask here for tips!!
They suggested ( fuel pressure sensor on filter housing/ fuel regulator/ failing pump) Im guessing if the pump was failing it would be more likely to play up when driven harder??? Also this has now got alot worste since i fitted a new intercooler after i found mine was split ! Now its goining into limp mode all the time! Any ideas would be very helpfull here guys
