Fuel pump ground wire
Results 1 to 8 of 8
Thread: Fuel pump ground wire
    Dec 2011
    Where is the fuel pump ground wire in astra mk3 c14nz
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Re: Fuel pump ground wire
    Look near the fuel sender unit at the bottom of the tank
    Dec 2011
    Okay thanks mate, car is playing up quite a bit its only getting 2 to 3 volts at the fuel pump fuse getting the 12 volts at the relay and last night i was only getting to 7 to 8 volts at the pump plug then came back to it and was only getting 2 to 3 volts ?
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Most likely will need the ground replacing, just take it locally, remember red with blue stripe is +, don't earth the pump to the tank you should be able to lift the rear seats and see the cover for the pump, earth it around there somewhere
    Dec 2011
    cant seem to see the earth wire mate
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    should be in a plug near the sender unit underneath the car, there are 2 plugs, one for fuel gauge and one for the pump
    Dec 2011
    i found it mate, ran a wire from the plug up at the fuel pump and attached it to the body at the back seats and it started up no problem whats the best way to attach the wire to the body of the car ?
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Either drill it and bolt it or self tapper or find a smallish bolt and ring terminal the end for the bolt
