Corsa B compatible speedo
Results 1 to 4 of 4
Thread: Corsa B compatible speedo
    Jan 2012
    Sussex
    Corsa - C20XE
    Afternoon.
    I've got what I believe is a C20XE in my '96 1.2 8v Corsa B.
    The standard gauge wouldn't normally be a problem but I've been having issues with it and have been told it's likely faulty. - The engine management light is constantly on and other random faults flash up which shouldn't be present.
    As it's the 1.2, it doesn't have a rev gauge which I'd like, I was thinking about just getting the 16v Corsa speedo, as I know it would fit. But having the XE engine fitted was thinking it would be more appropriate to fit the correct speedo for the engine?
    What clusters fit in this dash without looking butchered?
    Wasn't sure if the Astra dash would fit nicely compared to the Corsa 16v
    Astra: -AWAITING PHOTOBUCKET TO RESPOND FOR PICS
    Corsa: " "
    I only bow under braking
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Re: Corsa B compatible speedo
    Mk3 Astra clocks should fit
    Jan 2012
    Sussex
    Corsa - C20XE
    Perfect, just what I had in mind. - Should be a better match to the XE too
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    If yours has cable speedo it should be quite easy to do
