Astra mk3 brakes going to the floor
Results 1 to 6 of 6
Thread: Astra mk3 brakes going to the floor
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Have noticed when engine is off pedal is stiff but when running the pedal travels to the floor, have bled the brakes twice and there are no leaks is it the master cylinder ?
    Aug 2010
    Amsterdam
    5-door Astra MK2 C20XE
    Re: Astra mk3 brakes going to the floor
    Could very well be, some here on the forums have reported this having been the cause in their case. A scratched piston or wall can cause air to be sucked in, so it's definitely worth checking.
    Other possible causes I have encountered are spring clips being incorrectly placed pusing the calipers apart instead of pulling them together and calipers swapped left/right which places the bleed nipples UNDER the hose connections. The latter will make them impossible to bleed...
    If this is not after placing them new on the car the MC is the main suspect...
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Calipers, pads brake lines are new and no leaks can be seen on any Caliper front or back or brake line and fluid level doesn't drop so it must be the piston or seals on the MC, cheers mate needed to clarify that before I bought a brand new one
    Aug 2004
    glasgow
    astra 4x4 C20LET TURBO, v
    Is it a m/c with 4 outlets or gsi.
    Aug 2010
    Amsterdam
    There are kits to refurbish the MC mate... might be worth a try first...
    Still with newly fitted brakes I always doubt the MC is the problem, so many options as to why it's not bleeding properly.... You certain about the L/R placement of calipers and the springs? Might save some money putting up a pic or two, some eagle eyed people around on forums....
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    4 outlets mate and Calipers are fitted fine not wrong way round and springs are pushing in
