Airbag Code
Results 1 to 8 of 8
Thread: Airbag Code
    Nov 2007
    Airbag Code
    Hi
    my airbag light is on, the car has been in an accident before I had it. It looks as though the airbags have been replaced. I code read the ecu with opcom and got the following errors, do I need to replace these parts or get the airbag module cleared by a specialist?
    B0026 - Driver Airbag Squib Circuit High Resistance
    (00) - Not present
    B0065 - Driver Pretensioner Circuit High Resistance
    (00) - Present
    B0058 - Passenger Pretensioner Circuit High Resistance
    (00) - Present
    B0017 - Passenger Airbag Squib Circuit High Resistance
    (00) - Not present
    B1000 - Electronic Control Unit Not Reusable
    (03) - Not present
    Sep 2009
    yorkshire
    Re: Airbag Code
    you need a new airbag module or the crash data reseting try these
    Airbag ECU Crash Data Resetting and Removal Services Only £30
    Nov 2007
    Re: Airbag Code
    Quote Originally Posted by razledazle View Post
    Do the pretensioners need to be replaced as it says present?
    May 2008
    Re: Airbag Code
    If i replaced the pretensioners do you think that would clear the fault? as the last cod states not present for ecu not reusable
    Moderator Melv's Avatar
    Dec 2006
    KEITH, N.E. SCOTLAND
    1.8 Corsa Merit + ACT
    Re: Airbag Code
    Why do you have two user names?
    May 2008
    Re: Airbag Code
    Quote Originally Posted by Melv View Post
    omg i have no idea!
    Oct 2010
    Covas/Tabua - Portugal
    tigra A 1.6 16v
    Re: Airbag Code
    What car is this in, had similar things show up on me tigra, but the bulbs bin taken out the dash......
    LET THE THRILL OF SPEEDOVERCOME YOUR FEAR OF DEATH
    May 2008
    Re: Airbag Code
    out of an 04 combo
