parts quiz astra gte 16v
Results 1 to 8 of 8
Thread: parts quiz astra gte 16v
    MIGClub Member scooby-KILLER's Avatar
    Mar 2008
    unknown
    BADGER spec GSIT WIP
    can you tell me what these are for?, 1 will be abs ecu the rest is??
    By scooby_killer at 2012-01-01
    Oct 2005
    uk
    Re: parts quiz astra gte 16v
    Quote Originally Posted by scooby-KILLER View Post
    1 dip beam module
    2 no idea
    3 check control unit
    4 passenger side footwell loom plugs (lights, indicators, and loads else)
    5 abs ecu
    6 board computer connector
    Mar 2008
    unknown
    1 was behind the heater controls it that right?
    2 is in the drivers footwell under ecu
    3 so what does it control?
    4 so in theory any issues in there shouldnt STOP the car running?
    5 thought as much
    6 was NOT conected to any thing just tapped to the loom behind the clocks
    cheers for your reply
    Sep 2011
    Bedford
    MK2 astra gte
    5 thought as much
    1 yes
    2 central locking I think from what I remember
    3 the warning lights in the middle of the dash, for bulbs out ect.
    4 no
    6 The trip computer that was optional, goes where the clock is normally.
    Mar 2008
    unknown
    ah ok
    the central locking was working from the key fob but since i removed alarm (still not found a control box for it) it wont work, there was 2 wires that when joined locked the doors but they were in the pass foot well
    cheers chap
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    I think the one with xj on it is security module basically the alarm you removed, that is the control box for it, it's in the exact same place as the mk3 Astra under the ecu in the drivers kick panel
    UK
    Cav turbo and XJR
    2 central locking
    3 bulb failure module and check control for the orange lights
    Mar 2008
    unknown
    nice 1 guys,
    need to id them all so i can trace any lose wires and re-home them going to get ita all back in and working tomorow hopefuly as want it back up and runing so i can sell it
