wiring warning lights up on digi dash
Results 1 to 9 of 9
Thread: wiring warning lights up on digi dash
    Feb 2006
    leeds
    nova
    the digi dash itself works but the warning lights do not
    are all the warning lights powered by the individual live wires from the car
    example connect the brown dash wire to earth then connect say the wire for high beam warning light to live the light should come on right? even though the rest of the dash isnt wired up
    if i cant get round the problem could i install leds into the dash housing wire them all to the same earth an wire their lives to each warning light wire coming from the car ? instead of using the dash plug
    UK
    Cav turbo and XJR
    Re: wiring warning lights up on digi dash
    Quote Originally Posted by dan22leeds View Post
    Correct. The warning lights use the black plug. Make sure the bulbs are fitted.
    Some bulbs are active ground (like handbrake), so need need the black wire connecting to + and the signal wire grounding.
    Feb 2006
    leeds
    nova
    not all the warning lights run off the black plug though some are shared with the white plug
    thing is i ve changed my dash so all the warning lights are now on the right hand side instead of scattered around inbetween some that arent used
    are the warning lights found on the right of dash all active ground? that would make sense why they wouldnt work earlier
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    If I remember rightly, all the warning lights for the bottom row of the dash are on the black plug while the warning light for the oil pressure and alternator is on the white plug.
    UK
    Cav turbo and XJR
    Tell me what the functions of the old lights are then, that you have reused.
    Things like ABS, choke, brake fluid, handbrake, ecu light are active ground.
    Indicators and main beam are active high.
    Feb 2006
    leeds
    nova
    i removed the strip with the different warning symbols on from the bottom of the dash,
    cut it an put all the symbols that i need on the right of the dash so for example if a blue wire on the black plug powerd a warning light the bulb is still there but the symbol may now be different
    my car has no ecu abs etc so i only need the basic warning lights
    UK
    Cav turbo and XJR
    You need to find out what the old symbols on the right of the dash used to be. And then what the new symbol is.
    I can then tell you how much you have buggered it up, but I guess you have an idea by how many lights are working correctly.
    Feb 2006
    leeds
    nova
    i m getting there slowly
    are the following active ground or high active
    main beam warning ( high active?) white wire
    side an headlight warning? green /grey wire
    fuel gauge warningblue/black wire
    battery warning blue/whire wire
    oil warning blue green wire
    oil pressure blue yel
    what colour is brake fluid warning light brown + blue?
    UK
    Cav turbo and XJR
    main beam warning ( high active) white wire
    side an headlight warning? green /grey wire active high (so the other end of the bulb is connected to earth brown)
    The rest goto the white connector so I assume you havn't messed with them ?
    battery warning blue/whire wire active low
    oil warning blue green wire active low
    brake fluid warning light brown/red or brown/white active low
