i need to reduce a plug gap to 0.80mm
none of the blades on my feeler gauge have specfic measurement on them
each blade has two numbers onit i assume the top number is metric
the blades i plan use to make 0.80mm look like this
022
559
mm
028
711
mm
030
762
mm
if the top numbers are metric then is that the correct measurement
i tried to convert 0.80mm on google an the figure it gave didnt add up to the lower number on the gauges
