astra gte digi dash (oil level) where to connect
Results 1 to 11 of 11
Thread: astra gte digi dash (oil level) where to connect
    Jan 2008
    newcastle
    mk4 astra redtop/cav
    on the gte digi dash it had the oil level mines is showing full atm
    i have an xe in the astra so do you connect it to the oil level at the front of the sump ??
    dont want to blow anything up hence the question
    thanks in advance gilly
    Nov 2007
    nottingham
    astra H 1.9 td, corsa 4x4
    Re: astra gte digi dash (oil level) where to connect
    Hi all the lines are for the oil pressure, you connect it where the oil light sensor is, but you do need the right sensor, i think this is the right one... Vauxhall C20XE C20LET Oil Pressure Sensor Astra GTE GSI | eBay
    Jan 2008
    newcastle
    ahh thanks mate i took it to be oil level lol
    Nov 2007
    nottingham
    The one on the sump i think is for a warning oil level message..
    Aug 2010
    Amsterdam
    5-door Astra MK2 C20XE
    And the warning light I think should be on the check control box...
    Nov 2007
    nottingham
    The oil warning light is a red box around the oil can top left hand corner of the clocks if i remember right....its been about 9 years from the last time i seen them working in my old 1.0l nova lol
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    There are two connections on the digidash. One is for the "oil pressure low" which is the flashing red bar around the oil symbol on the dash. This connects to the existing oil pressure switch if you don't have the combined switch and pressure sender.
    The other wire from the digidash connects to the second terminal of the sender if you have the correct sender. The sender has a variable resistance depending on the oil pressure and this will make the gauge on the digidash read correctly.
    The oil level sender is to sense when the level of the oil is below a certain point rather than the pressure of the oil.
    Jan 2008
    newcastle
    thanks guys for the info ill need to get a pressure switch for it would rather it was working
    Jan 2008
    newcastle
    would a standard xe oil pressure switch for running cali oil guage work ??
    UK
    Cav turbo and XJR
    Not a standard XE no,
    but a 2 pin calibra one 1995 on will work.
    Jan 2005
    Cumbria
    Cav GSi & Cav Turbo
    I fitted GTE digi dash in my Cav yrs ago. ( well my mate did it for me)
    He wrote this out when he did it, if it helps.
    Make sure you've got the right transducer as there's 16v & 8v.
    Owns: Cavalier GSi & Cavalier Turbo
