Been doing a lot of maintainence to my Cav SRi Turbo over the last few months - lots of welding, new fuel tank, fuel lines, rear axle bushes, rear calipers & more. I`ve also replaced all rigid brakes lines (except from m/cyl to modulator) & in doing this I`m pretty sure the ABS pump has drawn in some air.
I`ve bleed the brakes a few times now (with a Power Bleeder) & am left with seemingly fully functional but very spongy brakes. I`m guessing the pump won`t expel the air in it till its in operation.
My questions - is there any way to `excite` or trick the pump into operating ? Would bleeding the system with the engine running help or could something else be causing the problem.
Any help suggestions appreciated
Rich
