speedo on r25-r28
Hi there,
I have a kadett b that I'm putting a c20let into running through a r25-r28 gearbox. The problem is the omega uses the abs sensor on the wheel to send a signal for the speedo. So was wondering if anyone has any ideas as to how I will get the speedo to work without using the abs sensor. Isn't there a way to use an aftermarket hall effect sensor or something similar?
