Cavy Windows
Results 1 to 7 of 7
Thread: Cavy Windows
    Oct 2009
    Ayrshire
    Cavalier GSi 2000
    Cavy Windows
    Got a cavy gsi last week with a few small issues nothing major. None of the windows work checked the fuse it looks ok so is this the actual switches or the motor?? Any help appreciated
    Sep 2009
    Isle of lewis
    Cavalier turbo, mk2 golf
    Re: Cavy Windows
    id first check the switch in the centre console mate, sometimes it can come loose, take it out and make sure its back on secure, and if you can use a multimeter or test lamp to check you have a positive and a neg at the switch and see if that helps
    Oct 2009
    Ayrshire
    Cavalier GSi 2000
    Re: Cavy Windows
    ok cheers mate
    Jan 2008
    newcastle
    mk4 astra redtop/cav
    Re: Cavy Windows
    yeah some times the switch unit in the middle goes not realy anything els to go wrong apart from the motors
    just make sure its plugged in correctly
    Oct 2009
    Ayrshire
    Cavalier GSi 2000
    Re: Cavy Windows
    The switch unit in the middle seems really tight. not got much give on it should it be like this? dont want to break anything taking it out lol
    UK
    Cav turbo and XJR
    Re: Cavy Windows
    do the front buttons light up orange with the ignition on ? do your mirrors work ?
    THe unit clipped to the rear of the switch can go faulty.
    The switches are plugged in under the handbrake grip (that triangular cover)
    pie
    pie is offline
    May 2009
    blackwood
    Cavalier GSI 4x4
    Re: Cavy Windows
    as above they cant be trickt to remove but the they pull out
    do they light up?
