I have a 2000 reg 12v corsa b with a early xe in it, it has been running in the car for over a year now. the other day i was having problems with the starter, at first it was just clicking when i was trying to start it, my first thought was my batter was on its way with the cold weather affecting it, there was no dimming of the dash light just flickering, it started right up after 4 or 5 goes, the next morning it happened aegean but did not want to start, this time it was cutting all the electric's from the car, ignition was fine and as soon as i went to start the car, everything in the car cut out for 20/30 seconds, i gave it a jump and it started right up and ran fine.
so i was thinking i need a new batter because it might not have enough current to turn the engine, got a brand new bosch one and the same thing is happening, as soon as a go to start the car, it cuts everything out, i thought i would try the light and indicators so when i did, it is cutting the full car out as-well!! my head is in a real pickle as it just happened over night! nothing new has change to the car that i have done.
i am now thinking there is a ground problem some were, could that be right, any specific place to look, could it be a short circuit some were!? and anything off the top of your heads were it could be.
As much feed back as possible will be gate as at this time of the year the car is more needed than normal.
Thank you steven
Not familiar with the Corsa wiring but black wires on Vauxhalls are generally switched ignition live wires
