Corsa GSI Engine Mount HELP PLEASE!!!
ok so im dropping a c16xe engine into my 12v shell and i need the drivers side engine mount. The engine doesn't have power steering or air con so im not sure what mount to use as i know they normally have either the power steering pump or air con bracket (cant remember which) thats all one piece with the engine mount. I'm getting myself in a pickle now, people are telling me different things so can someone please put my mind at rest and shed some light on the situation, PLEASE. Any help would be much apprciated. Also if anyone's got one they want to sell please get in touch. Thanks
Re: Corsa GSI Engine Mount HELP PLEASE!!!
3 bolts into front of block and 2 onto your inner chasis? if so im pretty sure its a c20xe (redtop) mount that can be used or give the likes of LMF a ring they sell the correct mount and will know what you need
yeah thats right mate, 3 on the block, 2 on the chassis. never heard of lmf before but ill check them out and give them a bell. thanks for your help
no problem mate LMF stock everything you need realie for most of the vauxhall conversions being done. i think its around £30 deliverd
