heated seats
iv got a mk3 astra wiv calibar heated seats in does any1 no if i can wire thm up or hw to do it ?????
Re: heated seats
yes i know, you use wires and a thing called searching......
sorry so you will understand
ye i kno hw 2 srt t, u use wirng n d www or sumfin
Re: heated seats
yes you can
probably you allready have the wires
just need the relay and the fuze
Re: heated seats
switches go near the handbrake.
don't need a relay
Re: heated seats
If they an option (the heated bit), you'll probably find the wiring to the seat under the centre console, or perhaps behind the lower dash panel. For switches, you may be able to find a panel with the switches fitted already or, if there are blanking covers, just the switches that you can fit into the holes.
Sorry I can't be much help - you'd probably get more info' on some of the Astra forums.
