opcom
Results 1 to 7 of 7
Thread: opcom
    Nov 2003
    liverpool
    nova,vectra,zafera
    opcom
    hi am after a lead an reader thingy for a corsa b 1.2 16v on a v plate ive tryed the paper clip thing and it dont work ive looked on ebay but theres loads of them what 1 should i be buying ??
    May 2002
    Rainham, Kent, UK
    FWD LSD C20LET Calibra
    Re: opcom
    Both op-com and opel-scanner will do the job. You can either buy clones from eBay (much cheaper) or buy the genuine items (although much more expensive). Ideally you want WinXP laptop. op-com doesn't (or rather its very difficult) to get it working on Win7. opel-scanner will install/work on anything from WinME to Win7. However if you just want to read ECU fault codes then there are cheaper alternatives from Halfords.
    www.topbuzz.co.uk : FWD LSD C20LET Calibra
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Re: opcom
    Have you tried the pedal test? Although I'm sure the paperclip test should work on that car.
    They're there, in their room.
    Nov 2003
    liverpool
    nova,vectra,zafera
    Re: opcom
    pedal test dont work on the corsa will work on me zaf altho it flashes 5 times then stops then another 5 an so on, so no idea what that means..
    found this on ebay (dont no if can post links ) OP-COM VAUXHALL OPEL V CAN BUS OBD2 DIAGNOSTIC OPCOM FAULT CODE READER SCANNER | eBay
    will this 1 work ??
    Oct 2003
    england
    Re: opcom
    couldnt get myn to work on windows 7 tried everything, it worked three times and then locked itself
    May 2002
    Rainham, Kent, UK
    Re: opcom
    Quote Originally Posted by crash_ndie View Post
    will this 1 work ??
    Yep, that's a op-com clone. It should work but there are so many clones from Japan/China being imported in and sold in the UK. Its pot luck if it will work, but for £20 you could try. If you only have Win7 then you can use virtual WinXP in Win7 (this is what I use - works just like WinXP and my op-com works just fine with it inc the USB drivers).
    Nov 2003
    liverpool
    nova,vectra,zafera
    Re: opcom
    thanks mate ill give it a bash
