i plan on buying a digi dash for my corsa but how do i get it to work with may sensor in the gearbox as its not cable ???? and anything else i need to know i will be geting everything with the clocks as far as i know
Hit search, covered already.
ok that didnt help at all all i want to know about is the speedo cause it not cable any1
thks alot for your help but i have already looked at alot of these including this 1 still confused and i see people saying the dont read right so have to find out more
As far as i'm concerned, if you used a matched transducer that came with the digi dash, you'll be fine.
ya the problem is im almost sure the are diff but will look more in to it the man im geting it off had it in a corsa befor so he might know
thks again for all ur help and if i find out i will post it up
If the speed doesn't read right then I sell a converter which should correct it![]()
I build and sell a converter that will correct the speed if its out - they are £35.
