I was wondering how you would go about wiring up the obd port into your Astra mk4 with a c20let because I could do with trying to read the ecu any ideas guys?
Anyone?
just connect the OBD wire from the port where you removed the old ecu to your new ecu brown and yellow if i remember correctly
If at first you dont succeed... CHEAT!
thank you very much ill do this tommorow and see what my ecu codes are![]()
