LOW VOLTS! 11.9V with engine running, 11.1V with headlights and heaters
Closed Thread
Page 2 of 2 FirstFirst 1 2
Results 26 to 39 of 39
Thread: LOW VOLTS! 11.9V with engine running, 11.1V with headlights and heaters
  1. #26
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: LOW VOLTS! 11.9V with engine running, 11.1V with headlights and heaters
    i thought you had tried a jump lead from batt positive to the starter terminal?
    SHoNkyOpELs.de
    Jul 2009
    Tyne & Wear
    Corsa SRI Z20LEH, B X14XE
    i have, but it was a old crappy cheapo thing with a bodge job connection on it, and i had to leave the alt cable layin in the bay while i tried it...... i want proper cable, thicker, because somethings had to fry it in the 1st place.....all crimped with the correct things and everything linked as it should be.
  4. #28
    Jul 2009
    Hants/Lincs
    Halfords sell pre made cables
  5. #29
    Jul 2009
    Tyne & Wear
    Cheers, defo starter rated cables? all crimped with the correct ends etc?
    Ive nicked some welders cable from work, nice thick stuff, tri-rated... that should cope with it providing i can find lugs etc to fit the battery and motor and alt
    Would prefer pre made stuff though, rather then me fannying on all day
  6. #30
    Jul 2009
    Hants/Lincs
    Should do to get you going
    halfords battery cable - Google Search
  7. #31
    Jul 2009
    Tyne & Wear
    top man, top man!! id looked on halfords site and rang some tart this morning who said noooo we dont sell anything like that.....mind she did say, "a starter what for what..."
  8. #32
    Jan 2008
    newcastle
    mk4 astra redtop/cav
    sorry dont mean to sound daft but how have you wired your starter up ??
    heres diagram some people seem to get mixed with and put both = & - on the terminals
    hope this is some help
  9. #33
    Jul 2009
    Tyne & Wear
    all wired up correctly mate but thanks for the picture....
    I HAVE FOUND THE PROBLEM!!!!! SWEAR!CURSE!SWEAR!CURSE!SWEAR!CURSE!SWEAR!
    IT WAS THE BASTARD POSITIVE CABLE, SOME WALLY HAS JOINED IT....AND DONE A PRETTY CRAP JOB AT THAT TBH. SHOULD NEVER OF BEEN JOINED!!! FEKING THINGS GOT ABOUT A METRE'S PLAY ON IT!
    SCRAPED THE BATTERY TERMINAL AND THE 4 INCHS OF CABLE ATTATCHED TO IT...... NEW BATTERY TERMINAL AND RE-CRIMPED TO REMAINDER OF CABLE ATTACTHED TO MOTOR....... SOLVED!
    NOW STARTING BETTER THEN IT EVER HAS, ALWAYS SOUNDED LIKE A BIT OF A WET FART TBH.... AND EVERYTHING IS NICE AND BRIGHT AND FULL OF POWER!
    THANKS TO ALL THAT HELPED OR HAD SOME INPUT! If anyone needs a z20leh alt or starter.... there tested and working lol £120 down the drain!
  10. #34
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    Glad it's sorted - better keep the 'new' spares - you'll probably need them a week after you sell them...
  11. #35
    Jul 2009
    Tyne & Wear
  12. #36
    Jan 2008
    newcastle
    glad you got it sorted mate its amazing how something so simple can cause a massive headach
  13. #37
    MSG
    MSG is offline
    MIGClub Member MSG's Avatar
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    hence why it is better to spend some time diagnosing things foirst instead of just going out to replace suspect parts, i.e. check that all voltages etc are present when required under full loaded condition, in your case if you had placed a DVM (digital volt meter) or even a light bulb at the starter motor terminal and earth, and got someone to crank, the bulb would have almost not have lit when trying to crank and may have lit fully well when not being cranked, thats how you learn and gain experience mate.
  14. #38
    Jul 2009
    Tyne & Wear
    Quote Originally Posted by MSG View Post
    True, Cant beat experience......... I shall live and learn as it was a costly mistake, at a bad time of year to chuck 120 snots away. In my defense though, its only b'coz its a conversion someones been lazy and cut + joined the two cables.... under normal circumstances that would have never crossed my mind to check for something like that. It was purely down to losing my rag and yanking the cable out the car, it must of been the only 2 inches of cable i hadnt pulled out the casing and checked over.
    Once again thanks everyone!
  15. #39
    MIGWeb Moderator
    Midlands
    Nowt
    Thread closed then if sorted.
Closed Thread
