calibra turbo master cylinder
might seem a stupid question but, on the cally m/c what outlets go where? does the front outlet(furthest from servo) go to the front brakes and rear outlet go to the rear brakes?
am fitting to a mk3 astra
cheers
Goes to the ABS unit there are 2 pipe entries on the rear of the abs pump!
Then you have four pipes leaving the ABS, it's in German VL vorne links = front left, VR vorne rechts = front right and HR + HL hinten rechts, hinten links.
Re: calibra turbo master cylinder
Can't use it then, you need a non abs mc with four outlets and as far as I know they didn't make a 23mm mc with non abs, they made a 22 mm from an Astra Gte 16v! and it could be that the pattern is different, which I think it is!
You have bigger calipers correct???
There is a non Abs for a mk3 on eBay right now but its a 22mm which is Standard size for gsi!
You have a cav v6 or Turbo One now which is 23mm!
I could be wrong but i dont think you will get a 23mm non Abs for a mk3.
Just read that you can use a splitter box from autovaux about ten quid this means you can use the mc u have now with non abs.
Hope that helps.
http://www.mk3oc.com/forum/archive/i...p/t-53250.html
i am going to run 1 line into a t piece then off to each side(front), then another line to my bias valve then another t piece and off to both rears. just need to know which outlet on the m/c is which?
