Hi all,
I'm in the middle of rebuilding my car. I've a converted drum axel to discs. However I've went to replace everything and don't know what diner car has been used.
Hope someone can help.
Thanks.
Hi all,
Thanks.
What car is it?
It's a Corsa B with a rear disc conversion. I'm trying to buy new discs, pads, plates etc...but don't know what setup i have
Pop the bits to your local motor factors who will be able to match them up to something.
the picture is of a dust shield ?
if you want us to guess what disk and pads you need, show us a picture of the disks and pads
It'll be worth measuring the diameter of the discs and the thickness. (although worn it'll give a rough idea)
Ok ill measure the disc. If it helps for just the bearing assembly is inside the disc.
Right guys. I've measured the diameter and its 260mm.
handbrake shoes inside the disk ? twin piston calipers ? and you say taper bearing holding the disk on ?
sounds like astra gte stuff
Ye handbrake shoes inside the disc.
Bearings are inside the disc and are tapered.
4 stud.
It definitely looks mk3 Astra/Cavalier:
Mk3 on the left, mk4 is on the right.
That does look like them. What model mk3 astra/cavalier?
Any 2.0 16v (not 4x4 though I think). Calibra is the same or Mk2 Astra 2.0 16v
Later mk3 Astras have sealed bearings/hubs rather than the taper bearings in the drum but shouldn't be an issue if you're renewing everything.
Hi,
Thanks for the help...I'm still a bit unsure as what car description to use when ordering them as the plates ive ordered already were from a 4x4 and some non turbo models. Is there a specific model that I could use that defo uses those back plates? Gsi2000? Sorry not too clued up on Cavaliers.
