Corsa fan rad switch
Page 3 of 3 FirstFirst 1 2 3
Results 51 to 61 of 61
Thread: Corsa fan rad switch
  1. #51
    Aug 2010
    Amsterdam
    5-door Astra MK2 C20XE
    Re: Corsa fan rad switch
    Right indeed, temp is just too high. Been working on my engine for the same reason lately. Might be a head gasket failure, you can buy a test kit for this which you connect to the expansion tank. When exhaust fumes are passing (even the tiniest bit that won't even ruin compression) there will be discolouration and definitely a head gasket failure...
    Been swapping the radiator for a full alloy one, it just barely helps. Gonna swap the pump first and inspect the old one, when that looks fine I am going to do that head gasket test.
    Can't hurt to do a compression test, if that test fails you've definitely got something to worry about....
    I know all about that headache of yours mate, I've been flushing the system as well, with clean water and a cup of washing liquid, then tons of clean water and again with vinegar, flushed with tons of clean water and put coolant in. Then got some very worrying brown rusty foam on top in the expansion tank the days after. Thought it was the porous head problem, so flushed the system once again and put some cheap coolant in and now it stays superbly clean. Made a difference to the temperature as well.
    My engine has been sitting still for a couple of years before I got to use it, had it checked and it was put away with some oil in the cylinders and all coolant drained, crankshaft was turned every once in a few weeks. Engine always ran fine from the start. It does seem however that a lot of gunk got dried up inside and the flushing softened it up, but it came out later on....
    Good luck with it and do try to get your sleep and stay healthy!
    Nov 2007
    nottingham
    astra H 1.9 td, corsa 4x4
    Quote Originally Posted by tiff_lee View Post
    Not sure what to suggest TBH but I know it shouldn't be required (fan always on).
    I hope you get to the bottom of it as well, you could give an aspirin a headache (quote: Layer Cake).
    lmao cheers mate
  4. #53
    Nov 2007
    nottingham
    Quote Originally Posted by Vinci View Post
    ok mate il do a compression test tomorrow, im hoping it will be ok cuz its only done 50 miles since the rebuild
  5. #54
    Nov 2007
    nottingham
    Right done a head gasket test that's fine stayed blue, also iv just noticed the 2 pipes that go to the header tank the one on the left if i take it off water is coming out if i rev it it gets faster, but if i take the one on the right off that comes from the top off the rad no water comes out even if i rev it, should water be running through it or is it just for expansion???? or could it just be lack of air flow through the rad?
  6. #55
    Aug 2010
    Amsterdam
    No, that one is just for the purpose of (auto) bleeding to get the last air out. When the system operates all the water goes through the large hose somewhat lower on the rad.
  7. #56
    Nov 2007
    nottingham
    thought so, well iv tried everything now should i remove the thermostats and try that??
  8. #57
    Aug 2010
    Amsterdam
    You could put the thermostat in boiling water to see if it opens... Some guys run without the thermostat, but I can't really approve of that, should just work fine with the thermostat, if it opens it opens...
  9. #58
    Nov 2007
    nottingham
    Il take the stat out and drop it in boiling water see wot happens, il let u know what happens mate
  10. #59
    Nov 2007
    nottingham
    Think its sorted now...well its a lot better anyway, i took the thermostat out and put it in boiling water....and nothing happened!! so im running it without the stat in now and iv also fitted this eBay - The UK's Online Marketplace it opens at 97c but my clocks are still saying its over 100c by time the fan kicks in, so i think my clocks are no good (ebay crap!!) so now when i drive around temps sit at about 92-95 but that could mean 90c with my f****D clocks
    So thanks everyone for you help
  11. #60
    Jul 2009
    Hants/Lincs
    I'd definitely get a replacement stat mate a working one will give you no problems. When cruising my let stays steady at 90 deg.
  12. #61
    Nov 2007
    nottingham
    Yea i was going to get one from vauxhall mate the one i got was a cheap one from a car shop near me, but.... i now need a new rad mines got a little leak on it! knew i should have put a new one on before i fitted the turbo...
  1. 10-01-2012, 02:55
