Electronic ignition help
Results 1 to 9 of 9
Thread: Electronic ignition help
    Jan 2011
    Hey guys,
    Been having loads of problems with my dizzy/msd ignition set up, gona sack it all off I think,
    Want to go to electronic ignition, ecu + cool pack,
    Really unsure what I need and how to do this, help on what it needed and how to will be much appreciated
    Will get a ball baring for can and dizzy blank off, Duno about what else is needed
    Cheers
    MIGWeb Moderator
    Midlands
    Nowt
    Re: Electronic ignition help
    What car and what engine out of interest?
    Jan 2011
    It's a mk1 jetta lol, but it's a c20xe engine early Redtop
    Jan 2011
    Anyone got any info on this?
    Been looking at mbe ignition only ecu's any recommendations?
    I've built this engine without the stock trigger wheel as it wasn't required at the time, anyone know of any after market bottom pulley ones with sensor or something?
    Would really appreciate any info people have got, am a bit of a noob with electronics that's why I kept it dizzy,
    Cheers
    Aug 2010
    Amsterdam
    5-door Astra MK2 C20XE
    From what I know about it...(never made the conversion myself)
    *M2.8 ECU
    *M2.8 Engine loom
    *Throttle position potentiometer instead of switch
    *Different plugs (FR8 LDC instead of FR7 DC-2)
    *Different injectors (blue)
    *Different ECT (temp sensor) (Black instead of blue afaik)
    *Different MAF sensor, apparently it has a temp sensor for intake air temperature
    *Head is slightly different too, apparently there are some threaded holes necessary.. Is possible to have this work done on it though...
    *On the stock M2.8 engines the timing belt is different too, but that's not a necessity to convert afaik
    The rest are the obvouis things, like coilpack, blanking plate, bearing... as you already mentioned...
    Things mentioned may not all be necessary, and may not be the complete list...
    You can drop this in Google translate perhaps...some interesting info...
    http://www.ascona-info.de/C20XE_Motor.html
    Jan 2011
    Thanks for info man,
    I'm running twin 45's so all the injecter stuff not needed, litterly just the ignition side
    Northeast Kent
    cheaper method is H+H ignition solutions, they sell a mk2 cavalier stye optical setup in kit form (distributor, hall sensor, loom, ignition amp, coil) but more importantly can re-curve the mechanical advance to suit your application.
    admitedly its not MBE or weber alpha, but significantly cheaper and reliable.
    Jan 2010
    megajolt, im running it on a 20seh with r1 carbs
    you need
    megajolt ecu
    loom (diy)
    36-1 trigger wheel
    ford crank sensor
    ford coil pack and leads
    and either a tps sensor or vaccum line from the inlet
    Jan 2011
    have been looking at the h&h setup, anyone had any experiances with this? reliable?
    the c20xe engine im using is high spec, 230hp+ will the h&h give enough spark?
    cheers guys
