wondering if any one else has had the problem i am having after lowering the tie bar brackets on the front cross member and lowering the tca under the bottom arms like i have done with the lowering block. and now the steering is very heavy and it does not feel right at all. what are you ment to lower them by? 10 mm 20mm 25mm. or do you just lower the tie bar arm brackets on the cross member and leave the tca bolted on top of the bottom arm. any help and pics of what yous have done would be much appreciated
