Anyone have experience with wiring in an innovate lc-1 wideband controller??
Results 1 to 19 of 19
Thread: Anyone have experience with wiring in an innovate lc-1 wideband controller??
    Apr 2007
    Stafford
    Corsa Turbo
    as above just have a few questions for anyone that has wired in there own successfully
    Apr 2007
    Stafford
    Corsa Turbo
    Re: Anyone have experience with wiring in an innovate lc-1 wideband controller??
    anyone?
    Apr 2007
    Stafford
    Corsa Turbo
    right what im wanting to know is, when it talks about grounding the wires, would it be ok to run these wires from the LC-1 to the same ground that im using for my boost and oil pressure gauge??
    MIGClub Member HARBER07's Avatar
    Nov 2009
    East Anglia
    Can't see why not TBH. It does recommend using a separate ground point from ignition systems, ECU's etc, but I can't see you having an issue.
    Apr 2007
    Stafford
    Corsa Turbo
    i will give it a try anyway, its just in instruction it says put loom into the cabin, but if i have to attach earth to engine block, then means extending the wiring just to make those few go back into the engine bay, only other alternative would be to , get single bit of cable, ground that then route that into the cabin along with rest of the loom them solder them together
    Jan 2010
    Hemel Hempstead
    Vectra B C20let
    I'd be interested in this as well, it does say you should solder the LC-1 and gauge grounds to the same point and earth that, so it should be possible to bolt a ring tag to the chassis, it is looking for zero difference in the 0V potential.
    MIGClub Member bigron1988's Avatar
    Aug 2009
    southport
    570.6bhp corsa @1.9bar
    ive just put my grounds to the same point inside the car , its all working now with the ignition on, but no loom on the car so cant tell you if it is fully working
    carbon clad corsa gsi ,c20let big power build thread
    http://www.migweb.co.uk/forums/proje...lots-pics.html
    Apr 2007
    Stafford
    Corsa Turbo
    i may just solder all the grounds to a single wire then run the single wire to the block maybe
    Sep 2009
    Bristol
    VX220 Turbo, 485 BHP.
    Thats what I did and it worked fine.
    Less than 300 BHP makes the baby Jesus cry, more than 450 makes him a happy passenger!
    Apr 2007
    Stafford
    Corsa Turbo
    any of you lot recommend a switch and LED in one, that would work well for the calibration switch at all??
    Apr 2002
    Southwest
    Like its stolen
    any switch, there is almost zero current draw.
    Apr 2007
    Stafford
    Corsa Turbo
    nah i meant is there a switch someone can recommend that has an LED built into the switch so i dont need to have them both separate
    Apr 2007
    Stafford
    Corsa Turbo
    right ive got a week off, so going to get a move on and get this fitted. just one thing im wanting to know anything that needs to go to ground, inc the calibration switch and LED, can then ALL go to the same grounding point?
    Apr 2007
    Stafford
    Corsa Turbo
    right one last question, have it all wired in etc now, seems to power up fine, get a error code which is linked to the fact i dont have the sensor plugged in at the mo, will it affect anything/still be ok to use the car without the sensor being plugged in?? still waiting to get car booked in to get new sensor location fitted to exhaust
    Apr 2007
    Stafford
    Corsa Turbo
    right ive finally got round to fully fitting my sensor etc into the exhaust, done its calibration etc, turned the ignition off and unplugged sensor again so i could fit it into the exhaust, when i turn the ignition on again when its plugged back in etc, is it normal for the LED and gauge to flash for a few seconds?? then it shows something like 21.8 on gauge untill i start the engine then it starts fluctuating as im guessing it should do? havent actually driven the car yet with it in but have revved it up abit
    Apr 2007
    Stafford
    Corsa Turbo
    anyone??
    May 2009
    N Ireland
    1.4 16v Rally Nova
    Sounds perfectly normal. The flashing LED on start-up is the sensor heating up, once it is lit continuous then it is reading.
    Your lucky yours works, had nothing but bother with mine on the rally car.
    David
    Apr 2007
    Stafford
    Corsa Turbo
    does it matter if i start the car up before LED finishes flashing?? is it normal for the gauge to flash aswell??
    May 2009
    N Ireland
    1.4 16v Rally Nova
    No, start away. In fact it is better for the sensor to be still warming when you start the engine cold as it is also supposed to be bad for a hot wideband sensor to get hit with cold exhaust gases.
    Check out the Innovate user forum as it has lots of good info, tips, etc.
    David
