rev meter jumping in my LET calibra :)
My rev meter is reving buy it self - my car was c20xe and I put c20let inside - someone have a solution for this prob ? Many Thanks!
speedo is also from C20LET car ...
Re: rev meter jumping in my LET calibra :)
Is the rev counter wired to the ECU or the coil ?
Doms online shop - www.picbits.co.uk/catalog,bulbs,cable,heatshrink etc Please don't ask for general advice by Private Messages - PMs are for PRIVATE MESSAGES. General advice should be asked on the Forums !
If your engine ECU has a tachometer output try it on that.
Coil pulses are notoriously nasty spikey signals which could be causing the issues.
I think there is no ECU tachometer output.. I will check
