ll.
I'd suggest you have a good think about what you're going to use the car for, what the roads (and sleeping Policemen) are like in your area, how much ride comfort you're prepared to sacrifice, if it's just going to be you in the car, or if you're going to be carrying a heavy load (passengers) frequently, etc...
Lowering that much without moving the mounting points will utterly bollocks the handling of your car by moving the roll centre far below the CoG and on top of that it'll bumpsteer like a ****. You'll have to make them ridiculously stiff to stop the increased roll the lower RC will cause, and then they'll have trouble staying on the ground and you'll have no traction.
ive ordered some 80mm all round , ive had 80mm rears before and seem ok , if the fronts at no good i will just use my 60 front and 80 rears
thanks for ure help
72.7K members
