bypassing oxygen/lambda sensor on c20xe
Results 1 to 12 of 12
Thread: bypassing oxygen/lambda sensor on c20xe
    Jan 2006
    edinburgh
    vectra gsi 2.5
    Smile bypassing oxygen/lambda sensor on c20xe
    hi guys i just had 2 do this 2 my cavy yesterday after changing the manifold,had read before you had 2 get at the wires going in 2 the ecu "pin20"......but found an easier way.if your car has the plug for the oxygen sensor,just plug the sensor in,then cut the wires going 2 the sensor "not the 1's comming from the car"ther will be 2 whites and a black,tape up the whites seperatly!,and earth the black wire.....job done! tested it an no fault codes appear after a good test run.hope this helps a few of you out? "DISCONNECT THE BATTERY WHEN DOING THIS THO" cheers
    Aug 2005
    Bradford
    various
    Re: bypassing oxygen/lambda sensor on c20xe
    why nt just leave the lambda senosr connected but in a lambda sleeve:
    or put a couple of washers in the normal hole where it would screw in so its slightly out of the main gas flow and dosnt get such a rich reading.
    This is my ride. There are many like it but this one is mine. Without my ride, I am nothing. Without me, my ride is nothing... Hoorah-Ha
    Jan 2008
    Glasgow Area
    4 cavs gsi 4x4/v6/td/mk2
    good thinking mate saves having to locate pin to to bridge it
  5. Remove Advertisements
    Dec 2002
    Essex
    Lada Riva
    Quick question , why do you need to bypass it ?
    I see that pic is a Ecotec ?
  7. #5
    Jan 2006
    edinburgh
    vectra gsi 2.5
    Thread Starter
    the sleeve thing looks cool! im bypassing it as i got a new manifold,but it doesnt have the hole for the lambda in it,so was throwing up the ecu light with code "13" open circuit.....and iv fitted an older AFM "adjustable 1" so had no need for the lambda,and had read before about grounding pin 20 on the ecu ,and the ecu then ignores any lambda input "like older xe's".....just didnt like the idea of tampering with ecu....hence doing what i did 2 bypass it,and just thought it might help or save some others time trying 2 acheive the same thing.been running for 2 days now with no ecu light or codes stored.all in all just a quicker way 2 bypass your lambda "if you needed 2"
  8. #6
    Dec 2002
    Essex
    Lada Riva
    Ahh , right ok ... yes I have owned a 20XE-J , with no CAT or lambda .
  9. #7
    UK
    Cav turbo and XJR
    Trouble is the ecu will be recieving a lean signal and therefore run the engine rich.
    This will not be optimum performance, damage the cat and use more petrol.
    It would not susprise me if after a week of running that it threw up an error code.
  10. #8
    Jan 2006
    edinburgh
    vectra gsi 2.5
    Thread Starter
    but the way it is earthed means the ecu ignores any signal recieved from the lambda.......like an xej ecu,it just relies on the AFM and knock sensors,and iv fitted an early adjustable AFM from a gsi with no CAT or lambda and can be set up properly now ...as before turning it made no difference as it used the signal from the lambda 2adjust air and fuel,and i have no CAT ,and have done over 100miles so far motorway and town and its driving spot on,no codes or lights ...."where as before i did this i got 50 feet down the road and it wasnt running or idiling correct,no power and ecu light was on"
  11. #9
    UK
    Cav turbo and XJR
    so you have earthed the black lambda wire going to the ecu then ?
  12. #10
    Jan 2006
    edinburgh
    vectra gsi 2.5
    Thread Starter
    there was 2 whites and a black,i earthed the black yes was out again tonight gave it fair bit of stick an was driving perfectly
  13. #11
    Northeast Kent
    pin 20 on the ecu is still open circuit, so it will still be expecting sensor signal. it took 2 days for my LET to come up with the ecu fault code when i disconnected my 02 sensor (it was faulty, switching too slow)
    just trying to work out what earthing the black wire will do, i think from memory thats the signal wire, i.e would normally be expecting a return a voltage to the ecu, if there is none i think it thinks the engine is on coast down, fuel cut off. need to look at it later with the pinouts !
  14. #12
    Jan 2006
    edinburgh
    vectra gsi 2.5
    Thread Starter
    but this mod doesnt work with LET's only xe's ....dont know why? but i know people with them that have tried it and it didnt work?but im on day 3 now and 150 miles in,and still no running probs,or ecu light an mpg has increased slightly,where as before it was an instant ecu light on,bad running and cutting out ect....ill keep an eye on it an let use know of any changes.cheers
