Will try to keep this short.
Car: Corsa Gsi
Problem: Exhaust
Put the standard back box on the car last year and it started to rattle even when just ticking over. Thought I had solved the problem but putting a bit of thin rubber on the rear axel held on with cable ties. Worked for a few month then started again. Rubber had moved so I sorted it. Problem solved...............aye for a few months.
Today it started again. Checked underneath and the rubber had mover again, so I slackened the rear exhaust clamp and moved the back box round a little to clear the rear axel. Test drive showed it was still rattlling like a junkie. The problem I think is that its either hitting the rear axel or the rear spring as its uber close to the exhaust see pictures below.
I have moved it to the best postion I could get it at, but still rattling a little.
I'm not sure if my problem lies with the fact my exhaust is a mix match of bits and bobs put on before i got car. It has standard manifold and stand cat but the centre section is not genuine. The pipe that comes out of the cat should be a one piece all the way to the back ( so I'm lead to beleave) but i have a pipe coming out the back of the cat the goes over the start of the center section. Or if its the rear axel or rear spring?????
If anyone has any hints or has had this problem before I would be grateful of advice.
Cheers Marc
