corsa b c20xe uprated master cylinder
Results 1 to 9 of 9
Thread: corsa b c20xe uprated master cylinder
    Feb 2011
    ellesmere port
    corsa redtop
    what master cylinder is a straight swap in my corsa b
    i am just wondering what master cylinder to put in my corsa, can i put 1 of a gsi or do i have to get 1 of something else, also do i need to change the servo aswell all advise would be great cheers guys
    Aug 2009
    bristol
    corsa b arden blue
    Re: corsa b c20xe uprated master cylinder
    what size brakes are you using?
    Feb 2011
    ellesmere port
    corsa redtop
    at the min they are 256mm but i am hoping to go upto 308mm
    Aug 2009
    bristol
    corsa b arden blue
    if its a standard xe 256mm will be enough but i think a upgrade for a mastercylinder is somthing from a mondeo if i remember right also use braided brake hoses
    Feb 2011
    ellesmere port
    corsa redtop
    do you no how i would go about that or would it be easier to get 1 of a corsa gsi
    Aug 2009
    bristol
    corsa b arden blue
    theres a thread somwhere gsi one is the same size i think
    Feb 2011
    ellesmere port
    corsa redtop
    what other cylinder and servo will fit in, i think i just found something that say a vectra a 1 will i this true?
    Aug 2009
    bristol
    corsa b arden blue
    not sure i started a thread like this a while ago someone also methioned a cav one
    Feb 2011
    ellesmere port
    corsa redtop
    dont surpose you no what cav 1 would fit?
