What spark plugs are you guys using with carbs xe
Results 1 to 2 of 2
Thread: What spark plugs are you guys using with carbs xe
    Sep 2007
    skegness
    mk3 astra gsi 4x4 45s
    took the plugs out of the 20xe with carbs as there jiggered. the one that were in are
    iridium bkr6eix ngk, did a search on flea bay and 1 set came up in amerca, stange thing is that there for a geo tracker 1.6 16v with a heat range of 6.
    any info greatly appreciated
    if in doubt give it a clout !!!!!!
    Sep 2007
    skegness
    Re: What spark plugs are you guys using with carbs xe
    i have bought some champion eon2 702 from halfords 21quidos, ill see howthese go probaly burn out within a couple hundred miles.
    any1 tryed rs turbo plugs.
