hi guys, im converting my astra to run bike carbs, its a 1.4 , ive changed the head,cam and changed from electric fuel pump to mechanical to feed the carbs
my question is that i will be using the nova sr dizzy that i had with the head and cam i bought, the problem is i did not recieve a coil for it
will i be able to use my coil along with the dizzy ? and if yes do you have any ideas with the wiring as i will be removing the origional spi wiring
i woul end up with the spi coil with ignition amplifier , the amp is the four pin one, if any of you guys could help me regarding the four wires going to the amplifer so i can get my car wird up and running i would be realy gratefull
many thanks in advance![]()
