M.o.t fail help
Results 1 to 13 of 13
Thread: M.o.t fail help
    Nov 2009
    skegness
    vectra c
    Angry M.o.t fail help
    hi all as above the vectra c 1.8 failed today need tyres windscreen bulbs wich i can get sorted but it also needs
    nearside front ( inner steering rack ) ball joint
    and... nearside rear upper suspension arm accessive play in pin bush
    i carnt find thies parts ( not sure witch part the ball joint is ) i can only find suspension arms when surching ebay and the like could someone pleas point me in the right direction it would be a real help im not bieng lazy but dont want to order the wrond ball joint cheers all
    Re: M.o.t fail help
    there are four bushes per arm on the rear, fun job to. Might be called a rear trialing arm bush.
    MIGWeb Moderator
    Midlands
    Nowt
    Re: M.o.t fail help
    Ask the tester whar bush needs changing to be 100% sure
    Nov 2009
    skegness
    vectra c
    Re: M.o.t fail help
    cheers people ill ring tomorrow does anyone know how hard it is to change a front windscreen on a 02 vectra eligance because ive been quoted £730 by autoglass
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Re: M.o.t fail help
    Just inside the steering rack gaitor there's a joint that lets the arm pivot to follow the wheel. Probably this as it says inner.
    The rear bush is very likely the top one just behind the wheel, very common to wear out on vectras, but very cheap and easy to replace with the proper tool.
    Windscreen will be glued in, so not the easiest of jobs.
    They're there, in their room.
    Nov 2009
    skegness
    vectra c
    Re: M.o.t fail help
    that is just what i needed pal thanks alot
    what tools will i need to replace ball joint and bush as i only have very basic tools
    thanks for everyons help
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    Re: M.o.t fail help
    How much? You fully comp? Got glass cover?
    Jan 2010
    Hemel Hempstead
    Vectra B C20let
    Re: M.o.t fail help
    Quote Originally Posted by seabodSXI View Post
    I was quoted £1500 for a windscreen on my Nissan Stagea.
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Re: M.o.t fail help
    You need to buy/ borrow/ hire the tool to press out the bush, you just wont' do otherwise. Only about £50 to buy.
    The steering rack thing needs a very big spanner, it has flats on it to allow you to spin the ball joint off. No idea what size though, but my big adjustable only just fitted.
    MIGWeb Moderator
    Midlands
    Nowt
    Re: M.o.t fail help
    Windsreen price is daft
    They are about £100 new
    Nov 2009
    skegness
    vectra c
    Re: M.o.t fail help
    thanks for all the comments lads its a real help now i know what tools to use i can crack on need to get the dam locking wheel nuts off think im going to have to weld a socket on as i think iv tried everything
    the quote was of autoglass and no not fully comp
    Jun 2010
    Grays
    1.7td Vectra 96
    Re: M.o.t fail help
    for the bushes you dont really need anything special (i mean expensive), a large socket just big enough to pull the bush into and some 8 or 10mm threaded bar with a lot of washers the size (roughly) of the bush.. oh and a fair bit of wd40... still a pain to do but a cheaper way of doing it
    Apr 2010
    southport
    2008 civic diesel
    Re: M.o.t fail help
    does it have the auto wiper sensor on the screen, this could effect the price, but not to the excess of £700, try a company local to you, i had one done in a bmw x5 for less that £250 supplied and fitted.
