Stuck suspension
Results 1 to 8 of 8
Thread: Stuck suspension
    Mar 2011
    Stuck suspension on corsa b merit
    Trying to get my front suspension off but can't. The only part I can see to undo is the bolt at the top but it just spins and can see the bar inside the suspension spinning. Where am I going wrong ?
    Apr 2005
    Derby
    Way too Fast :-/
    Re: Stuck suspension
    Read the top sticky on this page mate, because your yamaha motorcycle may need the forks straightening.
    Undo the 2 13mm nuts on the top of the turret in the engine bay.
    Undo the 2 19mm bolts on the leg (leg in to hub)
    The shock will come off.
    Mar 2011
    Yeah I tried undoing the bolt in the engine bay but it just spins and won't loosen
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    Has it got an allen or splined centre that you hold with a socket while undoing nut with spanner? A lot of cars do. It'd help if we knew what car yours was obviously
    Moderator Melv's Avatar
    Dec 2006
    KEITH, N.E. SCOTLAND
    1.8 Corsa Merit + ACT
    Quote Originally Posted by Adam88 View Post
    Hi Adam, see below.
    The point gixerboy is making is that you have not told us what vehicle you are having trouble with.
    help us to help you
    Regards
    Melv
    Sep 2004
    Nottingham M1 J26
    911. Loves: Dirty sluts.
    Reach inside the coil spring, lift up the shock dust cover and get some mole grips on the shock rod it to stop it spinning.
    Or better still get somebody with an airgun to zip them loose.
    Banned
    Dec 2008
    staffordshire
    range rover +let
    Impact gun will piss them off,or as ben says try some mole grips on the internal shock
