Re: Can anyone identify this Rear Anti-Roll Bar?
That's a strange one I have got a Astra mk4 estate one and it has bolt holes i'n the end no brackets apart form that it looks the same as urs
Forgot to add, it measures 22mm Diameter.
the top roll bar looks like my mk3 cav sri one, excatly the same infact and i think it was 20 or 22mm also
Hi Craig.
My PM basically said:
My photo is of a standard cav 16v front and rear ARB (top one in photo is the rear one).
The only 'upgrade' based on OE parts is to use cav V6 ARB's as both front and rear are bigger than the standard ones and the cav is the only v6 rear beamed car (as you know all calibras are IRS rear).
Can't remember sizes of the top of my head just just goggled:
Powerflex
IIRC the 20mm rear is tha cav v6.
Are you sure yours is 22mm, or 20 plus the paint?
I would google photos of whiteline ARB's.
Maybe they have copied the OE design.
Or....maybe someone has flogged you a V6 one by 'mistake'
Hope that helps.
Thanks for the reply's.
It looks like its probably a Cav V6 or 16V one then, ah well no matter, its still better than the nothing on my car at the moment.
I'm taking it into work tomorrow to be shotblast and painted...youve put me in the mood for redlmao
Cheers guys.
