Corsa B - installing gte digi dash! help!
Results 1 to 5 of 5
Thread: Corsa B - installing gte digi dash! help!
    Nov 2010
    Exclamation Corsa B - installing gte digi dash! help!
    Im about to buy a digi dash for my CORSA b, I am told i need to do some work to make it fit but that's okay i like a bit of fun, as ive done lots of crazy modifications myself inside the only bit that scared me is changing the transducer, I hear I need to get into my gear box how easily is this done ? could anybody explain how to change it ?
    All help would be greatly appreciated
    Thankyou !
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Re: Corsa B - installing gte digi dash! help!
    If its a boggo Corsa it will just screw onto the top of the gearbox in place of the speedo cable. 10 minute job if that
    Nov 2010
    Great! thanks, is the gear box easy to get to ? and how do i get to it ? thanks
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Quote Originally Posted by Corsa-Oli View Post
    Thats a bit of a worrying comment - lift the bonnet, look at the engine and its on the right hand side towards the bottom - you can't miss it - its what the two front wheels are connected to with long metal poles.
    Jan 2010
    hahaha
    the tranducer is held in by one 10mm bolt and its towards the back of the gear box near the gear selector bit. you might want to remove your bettery and tray to get to it and put your car in reverse as this will give you abit more room.
    i will also say that my corsa has an new type electronic transducers and it works perfectly with my digi dash. so if yours is electronic dont change it to the older type.
