electric steering
Results 1 to 4 of 4
Thread: electric steering
    Dec 2007
    bordon and alresford
    manta gte/bmw e30
    electric steering
    would like to fit corsa ect, electrical steering to my manta,fitting a m3 6cly engine,so it might be a little heavy for normal steering,how and what do i need to get.
    Aug 2010
    Re: electric steering
    You would need, at a minimum, the corsa EPS column and ECU. On the manta, there may be some fabrication work to do for the brackets and to get the column to fit to your existing setup.
    Does the manta have a speed sensor cable going to the back of the clocks? If not, you would need a speed sensor controller to get it working.
    I'll have a dig about for the wiring diagram i used to get mine working
    Dec 2008
    West Lothian
    MK 3 ASTRA GSI
    you ll have to make sure it s not of a 99 model corsa there was alot of problems with them for the power steering failing
    PS3 ID ferris_gsi ADD ME
    Dec 2007
    manta gte/bmw e30
    Ok guys thanks,will do more research to see what would be best.
