Results 1 to 2 of 2
Thread: c20xe into corsa b 1.0 12v
    May 2010
    Hi All
    I am sure some of you are aware i am currently putting a c20xe into my corsa b. When i bought the car the engine had been removed and they had cut straight through the wiring at the bulkhead. I have seen previous threads detailing the colours which i am happy with. I am unsure as to where the ecu will sit for the engine, and which way the loom runs into the car, do i pull the loom out out of the bulk head and feed the new engine loom through there. or does the c20xe loom sit in a different position. Has anybody put a c20xe in a 1.0 12v point in me in the right direction.
    many thanks
    Mowgly
    Dec 2009
    Llynfi Valley
    Corsa B
    Re: c20xe into corsa b 1.0 12v
    So your c20xe loom is fully intact yeh ??
    Iirc it is a bit harder due to the dash loom, try and get yourself another dash loom from a corsa as long as its not a 1.0 12v you will be fine. Swap it over and then your XE loom should be plug and play, thats how me and my mate done his. ECU should sit in the drivers footwell behind the kick panel.
    Hope that helps
