Results 1 to 2 of 2
Thread: c20xe to corsa wiring
    Oct 2009
    bershire, england
    Corsa B c20xe
    i know there are many posts regarding this issue but i have done the most i can from this and am now stuck.
    corsa side of the loom i have left. Red, Black and blue.
    Engine loom i have left. Red/white (unused), green/black, brown/black, blue/black, and another soft blue one.
    What do i do with these??
    Aug 2008
    Glasgow
    c20xe corsa sport
    Re: c20xe to corsa wiring
    XE loom
    Green - rev counter feed, wire to green on corsa plug (some corsas may not have this wire, in which case use a bullet connector and run a green wire to the rear of the clocks if you wish to fit a set with a revcounter.
    Brown/Blue - ECU light, match to corsa plug
    Brown/White - Diagnostics, match to corsa plug
    Brown/Yellow - Diagnostics, match to corsa plug
    Blue/red (thick) - Fuel pump feed, match to corsa plug
    Blue - Coolant temp sensor feed for dash clocks, match to plug
    Red/White - Autobox, unused in conversion
    Red/Blue (thin) - electronic speedo feed, match to corsa plug
    Red (large) - Battery +ve
    Black (thin) - Ignition live - move this inside and match it to the corsa plug
    Black/green - Aircon (unused in conversion)
