no power at deignostics plug
Results 1 to 13 of 13
Thread: no power at deignostics plug
    Jun 2010
    astra mk3 1.8 sport as a above any ideas guys
    MSG
    MSG is offline
    MIGClub Member MSG's Avatar
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    Re: no power at deignostics plug
    say check fuse
    Jun 2010
    hey msg there aint any for it so the guy with the fancy laptop
    Jun 2010
    all wires are in the plug but he recons there aint an in line fuse for it?
    Oct 2000
    Sunny Milton Keynes
    Bmw 3 series
    Check the wiring diagram in the haynes.
    eg, the one for the Vectra (only haynes I have near me at the mo) says F22 (20a) goes to pin 16 of the diag socket.
    Jun 2010
    thanks dav will give it a go is the wire diagram showing in line fuse then
    Oct 2000
    Sunny Milton Keynes
    Bmw 3 series
    The one I have does, and it'd be unusual for a live feed not to pass through a fuse first.
    Jun 2010
    many thanks bud thats wot i thought was weird but he had the laptop will check it the more just out of noseyness if the in line has blown would it stop the car from starting ?
    Oct 2000
    Sunny Milton Keynes
    Bmw 3 series
    Depends if that fuse feeds anything else.
    MSG
    MSG is offline
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    Sorry, Not sure what your diagnostic plug looks like, I can only check against a Calibra X20XEV plug. even this is all over the place in Haynes manual shown as X13 being the connector and which pin is which is hard to tell at a glance.
    I would think if your car is not starting then there could be a bad earth or some other electrical continuity problem including the ignition switch.
    are your dash lights on?, does it crank? and so on.
    Jun 2010
    msg its the same as last week got ignition lights BUT no ecu light. cranks no bother but no fuel pump spark etc .. the plug is the 16 pin one
    MSG
    MSG is offline
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    Its still not bstarting then? I will need to go back to that thread and check out so far what has been tested and done and see if there is anything else that I can suggest a bit later on then.
    Jun 2010
    up-date i have power to the dignostic plug so the guy wae the fancy laptop and software hmmmmm anyway pin 16 is reading 13v with jump leads on (battery flat) so back to fpr will do the checks MSG helped me out with on an earlier post and get back to u guys but if the voltage to the fpr pins is spot on i am thinking new fpr from vauxhall
