Results 1 to 4 of 4
Thread: OBD-II (OBD2) Fault Codes, Details and Help Guides
    MIGClub Member jamied's Avatar
    May 2003
    northampton
    loads of things
    If you have found you have got a few Fault Codes popping up, have a look at this site which can be a great help.
    Not only will it tell you what the fault code is you can also have a read of possible fixes and testing tips.
    OBD-II Trouble Codes - DTC Codes Car Repair
    J.N.D.Photography@hotmail.co. uk ...weddings, children, pets, cars, landscapes....just ask.
    May 2003
    northampton
    loads of things
    Re: OBD-II (OBD2) Fault Codes, Details and Help Guides
    P0001-P0099 - Fuel and Air Metering and Auxiliary Emission Controls
    * P0001 Fuel Volume Regulator Control Circuit/Open
    * P0002 Fuel Volume Regulator Control Circuit Range/Performance
    * P0003 Fuel Volume Regulator Control Circuit Low
    * P0004 Fuel Volume Regulator Control Circuit High
    * P0005 Fuel Shutoff Valve "A" Control Circuit/Open
    * P0006 Fuel Shutoff Valve "A" Control Circuit Low
    * P0007 Fuel Shutoff Valve "A" Control Circuit High
    * P0008 Engine Positions System Performance Bank 1
    * P0009 Engine Position System Performance Bank 2
    * P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
    * P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
    * P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1)
    * P0013 "B" Camshaft Position - Actuator Circuit (Bank 1)
    * P0014 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1) - See Trouble Code P0011
    * P0015 "B" Camshaft Position -Timing Over-Retarded (Bank 1) - See Trouble Code P0012
    * P0016 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
    * P0017 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B)
    * P0018 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A)
    * P0019 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor B)
    * P0020 "A" Camshaft Position Actuator Circuit (Bank 2)
    * P0021 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
    * P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
    * P0023 "B" Camshaft Position - Actuator Circuit (Bank 2) - See Trouble Code P0020
    * P0024 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) - See Trouble Code P0021
    * P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2) - See Trouble Code P0022
    * P0026 Intake Valve Control Solenoid Circuit Range/Performance Bank 1
    * P0027 Exhaust Valve Control solenoid Circuit Range/Performance Bank 1
    * P0028 Intake valve Control Solenoid Circuit Range/Performance Bank 2
    * P0029 Exhaust Valve Control Solenoid Circuit Range/Performance Bank 2
    * P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
    * P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
    * P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
    * P0033 Turbo Charger Bypass Valve Control Circuit
    * P0034 Turbo Charger Bypass Valve Control Circuit Low
    * P0035 Turbo Charger Bypass Valve Control Circuit High
    * P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
    * P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
    * P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
    * P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
    * P0040 Upstream Oxygen Sensors Swapped From Bank To Bank
    * P0041 Downstream Oxygen Sensors Swapped From Bank To Bank
    * P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
    * P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
    * P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
    * P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
    * P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
    * P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
    * P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
    * P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
    * P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
    * P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
    * P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
    * P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
    * P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
    * P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
    * P0061 HO2S Heater Resistance (Bank 2, Sensor 3)
    * P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
    * P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
    * P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
    * P0065 Air Assisted Injector Control Range/Performance
    * P0066 Air Assisted Injector Control Circuit or Circuit Low
    * P0067 Air Assisted Injector Control Circuit High
    * P0068 MAP/MAF - Throttle Position Correlation
    * P0069 Manifold Absolute Pressure - Barometric Pressure Correlation
    * P0070 Ambient Air Temperature Sensor Circuit
    * P0071 Ambient Air Temperature Sensor Range/Performance
    * P0072 Ambient Air Temperature Sensor Circuit Low Input
    * P0073 Ambient Air Temperature Sensor Circuit High Input
    * P0074 Ambient Air Temperature Sensor Circuit Intermittent
    * P0075 Intake Valve Control Solenoid Circuit (Bank 1)
    * P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
    * P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
    * P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
    * P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
    * P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
    * P0081 Intake valve Control Solenoid Circuit (Bank 2)
    * P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
    * P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
    * P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
    * P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
    * P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
    * P0087 Fuel Rail/System Pressure - Too Low
    * P0088 Fuel Rail/System Pressure - Too High
    * P0089 Fuel Pressure Regulator 1 Performance
    * P0090 Fuel Pressure Regulator 1 Control Circuit
    * P0091 Fuel Pressure Regulator 1 Control Circuit Low
    * P0092 Fuel Pressure Regulator 1 Control Circuit High
    * P0093 Fuel System Leak Detected - Large Leak
    * P0094 Fuel System Leak Detected - Small Leak
    * P0095 Intake Air Temperature Sensor 2 Circuit
    * P0096 Intake Air Temperature Sensor 2 Circuit Range/Performance
    * P0097 Intake Air Temperature Sensor 2 Circuit Low
    * P0098 Intake Air Temperature Sensor 2 Circuit High
    * P0099 Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic
    DTC Codes - P0100-P0199 - Fuel and Air Metering
    * P0100 Mass or Volume Air Flow Circuit Malfunction
    * P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
    * P0102 Mass or Volume Air Flow Circuit Low Input
    * P0103 Mass or Volume Air Flow Circuit High Input
    * P0104 Mass or Volume Air Flow Circuit Intermittent
    * P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
    * P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
    * P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
    * P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
    * P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
    * P0109 Intake Air Temperature Circuit Malfunction
    * P0111 Intake Air Temperature Circuit Range/Performance Problem
    * P0112 Intake Air Temperature Circuit Low Input
    * P0113 Intake Air Temperature Circuit High Input
    * P0114 Intake Air Temperature Circuit Intermittent
    * P0115 Engine Coolant Temperature Circuit Malfunction
    * P0116 Engine Coolant Temperature Circuit Range/Performance Problem
    * P0117 Engine Coolant Temperature Circuit Low Input
    * P0118 Engine Coolant Temperature Circuit High Input
    * P0119 Engine Coolant Temperature Circuit Intermittent
    * P0120 Throttle Position Sensor/Switch A Circuit Malfunction
    * P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
    * P0122 Throttle Position Sensor/Switch A Circuit Low Input
    * P0123 Throttle Position Sensor/Switch A Circuit High Input
    * P0124 Throttle Position Sensor/Switch A Circuit Intermittent
    * P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
    * P0126 Insufficient Coolant Temperature for Stable Operation
    * P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
    * P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
    * P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I)
    * P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1)
    * P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
    * P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
    * P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    * P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
    * P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
    * P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2)
    * P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
    * P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
    * P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
    * P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3)
    * P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3)
    * P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3)
    * P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3)
    * P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3)
    * P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3)
    * P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I)
    * P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I)
    * P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
    * P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)
    * P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
    * P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
    * P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
    * P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
    * P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
    * P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
    * P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
    * P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
    * P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3)
    * P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
    * P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3)
    * P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3)
    * P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
    * P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
    * P0170 Fuel Trim Malfunction (Bank 1)
    * P0171 System too Lean (Bank 1)
    * P0172 System too Rich (Bank 1)
    * P0173 Fuel Trim Malfunction (Bank 2)
    * P0174 System too Lean (Bank 2)
    * P0175 System too Rich (Bank 2)
    * P0176 Fuel Composition Sensor Circuit Malfunction
    * P0177 Fuel Composition Sensor Circuit Range/Performance
    * P0178 Fuel Composition Sensor Circuit Low Input
    * P0179 Fuel Composition Sensor Circuit High Input
    * P0180 Fuel Temperature Sensor A Circuit Malfunction
    * P0181 Fuel Temperature Sensor A Circuit Range/Performance
    * P0182 Fuel Temperature Sensor A Circuit Low Input
    * P0183 Fuel Temperature Sensor A Circuit High Input
    * P0184 Fuel Temperature Sensor A Circuit Intermittent
    * P0185 Fuel Temperature Sensor B Circuit Malfunction
    * P0186 Fuel Temperature Sensor B Circuit Range/Performance
    * P0187 Fuel Temperature Sensor B Circuit Low Input
    * P0188 Fuel Temperature Sensor B Circuit High Input
    * P0189 Fuel Temperature Sensor B Circuit Intermittent
    * P0190 Fuel Rail Pressure Sensor Circuit Malfunction
    * P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
    * P0192 Fuel Rail Pressure Sensor Circuit Low Input
    * P0193 Fuel Rail Pressure Sensor Circuit High Input
    * P0194 Fuel Rail Pressure Sensor Circuit Intermittent
    * P0195 Engine Oil Temperature Sensor Malfunction
    * P0196 Engine Oil Temperature Sensor Range/Performance
    * P0197 Engine Oil Temperature Sensor Low
    * P0198 Engine Oil Temperature Sensor High
    * P0199 Engine Oil Temperature Sensor Intermittent
    DTC Codes - P0200-P0299 - Fuel and Air Metering (Injector Circuit)
    * P0200 Injector Circuit Malfunction
    * P0201 Injector Circuit Malfunction - Cylinder 1
    * P0202 Injector Circuit Malfunction - Cylinder 2
    * P0203 Injector Circuit Malfunction - Cylinder 3
    * P0204 Injector Circuit Malfunction - Cylinder 4
    * P0205 Injector Circuit Malfunction - Cylinder 5
    * P0206 Injector Circuit Malfunction - Cylinder 6
    * P0207 Injector Circuit Malfunction - Cylinder 7
    * P0208 Injector Circuit Malfunction - Cylinder 8
    * P0209 Injector Circuit Malfunction - Cylinder 9
    * P0210 Injector Circuit Malfunction - Cylinder 10
    * P0211 Injector Circuit Malfunction - Cylinder 11
    * P0212 Injector Circuit Malfunction - Cylinder 12
    * P0213 Cold Start Injector 1 Malfunction
    * P0214 Cold Start Injector 2 Malfunction
    * P0215 Engine Shutoff Solenoid Malfunction
    * P0216 Injection Timing Control Circuit Malfunction
    * P0217 Engine Overtemp Condition
    * P0218 Transmission Over Temperature Condition
    * P0219 Engine Overspeed Condition
    * P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
    * P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
    * P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
    * P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
    * P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
    * P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
    * P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
    * P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
    * P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
    * P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
    * P0230 Fuel Pump Primary Circuit Malfunction
    * P0231 Fuel Pump Secondary Circuit Low
    * P0232 Fuel Pump Secondary Circuit High
    * P0233 Fuel Pump Secondary Circuit Intermittent
    * P0234 Engine Overboost Condition
    * P0235 Turbocharger Boost Sensor A Circuit Malfunction
    * P0236 Turbocharger Boost Sensor A Circuit Range/Performance
    * P0237 Turbocharger Boost Sensor A Circuit Low
    * P0238 Turbocharger Boost Sensor A Circuit High
    * P0239 Turbocharger Boost Sensor B Malfunction
    * P0240 Turbocharger Boost Sensor B Circuit Range/Performance
    * P0241 Turbocharger Boost Sensor B Circuit Low
    * P0242 Turbocharger Boost Sensor B Circuit High
    * P0243 Turbocharger Wastegate Solenoid A Malfunction
    * P0244 Turbocharger Wastegate Solenoid A Range/Performance
    * P0245 Turbocharger Wastegate Solenoid A Low
    * P0246 Turbocharger Wastegate Solenoid A High
    * P0247 Turbocharger Wastegate Solenoid B Malfunction
    * P0248 Turbocharger Wastegate Solenoid B Range/Performance
    * P0249 Turbocharger Wastegate Solenoid B Low
    * P0250 Turbocharger Wastegate Solenoid B High
    * P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
    * P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
    * P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
    * P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
    * P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
    * P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
    * P0257 Injection Pump Fuel Metering Control "B" Range/Performance Injector)
    * P0258 Injection Pump Fuel Metering Control "B" Low (Cam/R
    * P0259 Injection Pump Fuel Metering Control "B" High (Cam/R
    * P0260 Injection Pump Fuel Metering Control "B" Intermittent Injector)
    * P0261 Cylinder I Injector Circuit Low
    * P0262 Cylinder I Injector Circuit High
    * P0263 Cylinder I Contribution/Balance Fault
    * P0264 Cylinder 2 Injector Circuit Low
    * P0265 Cylinder 2 Injector Circuit High
    * P0266 Cylinder 2 Contribution/Balance Fault
    * P0267 Cylinder 3 Injector Circuit Low
    * P0268 Cylinder 3 Injector Circuit High
    * P0269 Cylinder 3 Contribution/Balance Fault
    * P0270 Cylinder 4 Injector Circuit Low
    * P0271 Cylinder 4 Injector Circuit High
    * P0272 Cylinder 4 Contribution/Balance Fault
    * P0273 Cylinder 5 Injector Circuit Low
    * P0274 Cylinder 5 Injector Circuit High
    * P0275 Cylinder S Contribution/Balance Fault
    * P0276 Cylinder 6 Injector Circuit Low
    * P0277 Cylinder 6 Injector Circuit High
    * P0278 Cylinder 6 Contribution/Balance Fault
    * P0279 Cylinder 7 Injector Circuit Low
    * P0280 Cylinder 7 Injector Circuit High
    * P0281 Cylinder 7 Contribution/Balance Fault
    * P0282 Cylinder 8 Injector Circuit Low
    * P0283 Cylinder 8 Injector Circuit High
    * P0284 Cylinder 8 Contribution/Balance Fault
    * P0285 Cylinder 9 Injector Circuit Low
    * P0286 Cylinder 9 Injector Circuit High
    * P0287 Cylinder 9 Contribution/Balance Fault
    * P0288 Cylinder 10 Injector Circuit Low
    * P0289 Cylinder 10 Injector Circuit High
    * P0290 Cylinder 10 Contribution/Balance Fault
    * P0291 Cylinder 11 Injector Circuit Low
    * P0292 Cylinder 11 Injector Circuit High
    * P0293 Cylinder 11 Contribution/Balance Fault
    * P0294 Cylinder 12 Injector Circuit Low
    * P0295 Cylinder 12 Injector Circuit High
    * P0296 Cylinder 12 Contribution/Range Fault
    DTC Codes - P0300-P0399 - Ignition System or Misfire
    * P0300 Random/Multiple Cylinder Misfire Detected
    * P0301 Cylinder 1 Misfire Detected
    * P0302 Cylinder 2 Misfire Detected
    * P0303 Cylinder 3 Misfire Detected
    * P0304 Cylinder 4 Misfire Detected
    * P0305 Cylinder 5 Misfire Detected
    * P0306 Cylinder 6 Misfire Detected
    * P0307 Cylinder 7 Misfire Detected
    * P0308 Cylinder 8 Misfire Detected
    * P0309 Cylinder 9 Misfire Detected
    * P0310 Cylinder 10 Misfire Detected
    * P0311 Cylinder 11 Misfire Detected
    * P0312 Cylinder 12 Misfire Detected
    * P0313 Misfire Detected with Low Fuel
    * P0314 Single Cylinder Misfire (Cylinder not Specified)
    * P0315 Crankshaft Position System Variation Not Learned
    * P0316 Misfire Detected On Startup (First 1000 Revolutions)
    * P0317 Rough Road Hardware Not Present
    * P0318 Rough Road Sensor A Signal Circuit
    * P0319 Rough Road Sensor B Signal Circuit
    * P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
    * P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
    * P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
    * P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
    * P0325 Knock Sensor 1 Circuit Malfunction (Bank I or Single Sensor)
    * P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
    * P0327 Knock Sensor 1 Circuit Low Input (Bank I or Single Sensor)
    * P0328 Knock Sensor 1 Circuit High Input (Bank I or Single Sensor)
    * P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
    * P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
    * P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
    * P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
    * P0333 Knock Sensor 2 Circuit High Input (Bank 2)
    * P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
    * P0335 Crankshaft Position Sensor A Circuit Malfunction
    * P0336 Crankshaft Position Sensor A Circuit Range/Performance
    * P0337 Crankshaft Position Sensor A Circuit Low Input
    * P0338 Crankshaft Position Sensor A Circuit High Input
    * P0339 Crankshaft Position Sensor A Circuit Intermittent
    * P0340 Camshaft Position Sensor Circuit Malfunction
    * P0341 Camshaft Position Sensor Circuit Range/Performance
    * P0342 Camshaft Position Sensor Circuit Low Input
    * P0343 Camshaft Position Sensor Circuit High Input
    * P0344 Camshaft Position Sensor Circuit Intermittent
    * P0345 Camshaft Position Sensor A Circuit Malfunction (Bank 2)
    * P0346 Camshaft Position Sensor A Circuit Range/Performance (Bank 2)
    * P0347 Camshaft Position Sensor A Circuit Low Input (Bank 2)
    * P0348 Camshaft Position Sensor A Circuit High Input (Bank 2)
    * P0349 Camshaft Position Sensor A Circuit Intermittent (Bank 2)
    * P0350 Ignition Coil Primary/Secondary Circuit Malfunction
    * P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
    * P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
    * P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
    * P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
    * P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
    * P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
    * P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
    * P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
    * P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
    * P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
    * P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
    * P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
    * P0370 Timing Reference High Resolution Signal A Malfunction
    * P0371 Timing Reference High Resolution Signal A Too Many Pulses
    * P0372 Timing Reference High Resolution Signal A Too Few Pulses
    * P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
    * P0374 Timing Reference High Resolution Signal A No Pulses
    * P0375 Timing Reference High Resolution Signal B Malfunction
    * P0376 Timing Reference High Resolution Signal B Too Many Pulses
    * P0377 Timing Reference High Resolution Signal B Too Few Pulses
    * P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
    * P0379 Timing Reference High Resolution Signal B No Pulses
    * P0380 Glow Plug/Heater Circuit "A" Malfunction
    * P0381 Glow Plug/Heater Indicator Circuit Malfunction
    * P0382 Exhaust Gas Recirculation Flow Malfunction
    * P0385 Crankshaft Position Sensor B Circuit Malfunction
    * P0386 Crankshaft Position Sensor B Circuit Range/Performance
    * P0387 Crankshaft Position Sensor B Circuit Low Input
    * P0388 Crankshaft Position Sensor B Circuit High Input
    * P0389 Crankshaft Position Sensor B Circuit Intermittent
    DTC Codes - P0400-P0499 - Auxiliary Emissions Controls
    * P0400 Exhaust Gas Recirculation Flow Malfunction
    * P0401 Exhaust Gas Recirculation Flow Insufficient Detected
    * P0402 Exhaust Gas Recirculation Flow Excessive Detected
    * P0403 Exhaust Gas Recirculation Circuit Malfunction
    * P0404 Exhaust Gas Recirculation Circuit Range/Performance
    * P0405 Exhaust Gas Recirculation Sensor A Circuit Low
    * P0406 Exhaust Gas Recirculation Sensor A Circuit High
    * P0407 Exhaust Gas Recirculation Sensor B Circuit Low
    * P0408 Exhaust Gas Recirculation Sensor B Circuit High
    * P0410 Secondary Air Injection System Malfunction
    * P0411 Secondary Air Injection System Incorrect Flow Detected
    * P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
    * P0413 Secondary Air Injection System Switching Valve A Circuit Open
    * P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
    * P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
    * P0416 Secondary Air Injection System Switching Valve B Circuit Open
    * P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
    * P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
    * P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
    * P0420 Catalyst System Efficiency Below Threshold (Bank 1)
    * P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
    * P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
    * P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
    * P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
    * P0430 Catalyst System Efficiency Below Threshold (Bank 2)
    * P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
    * P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
    * P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
    * P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
    * P0440 Evaporative Emission Control System Malfunction
    * P0441 Evaporative Emission Control System Incorrect Purge Flow
    * P0442 Evaporative Emission Control System Leak Detected (small leak)
    * P0443 Evaporative Emission Control System Purge Control Valve Circuit
    * P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
    * P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
    * P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
    * P0447 Evaporative Emission Control System Vent Control Circuit Open
    * P0448 Evaporative Emission Control System Vent Control Circuit Shorted
    * P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
    * P0450 Evaporative Emission Control System Pressure Sensor Malfunction
    * P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
    * P0452 Evaporative Emission Control System Pressure Sensor Low Input
    * P0453 Evaporative Emission Control System Pressure Sensor High Input
    * P0454 Evaporative Emission Control System Pressure Sensor Intermittent
    * P0455 Evaporative Emission Control System Leak Detected (gross leak)
    * P0456 Evaporative Emissions System Small Leak Detected
    * P0457 Evaporative Emission Control System Leak Detected
    * P0458 Evaporative Emission System Purge Control Valve Circuit Low
    * P0459 Evaporative Emission System Purge Control Valve Circuit High
    * P0460 Fuel Level Sensor Circuit Malfunction
    * P0461 Fuel Level Sensor Circuit Range/Performance
    * P0462 Fuel Level Sensor Circuit Low Input
    * P0463 Fuel Level Sensor Circuit High Input
    * P0464 Fuel Level Sensor Circuit Intermittent
    * P0465 Purge Flow Sensor Circuit Malfunction
    * P0466 Purge Flow Sensor Circuit Range/Performance
    * P0467 Purge Flow Sensor Circuit Low Input
    * P0468 Purge Flow Sensor Circuit High Input
    * P0469 Purge Flow Sensor Circuit Intermittent
    * P0470 Exhaust Pressure Sensor Malfunction
    * P0471 Exhaust Pressure Sensor Range/Performance
    * P0472 Exhaust Pressure Sensor Low
    * P0473 Exhaust Pressure Sensor High
    * P0474 Exhaust Pressure Sensor Intermittent
    * P0475 Exhaust Pressure Control Valve Malfunction
    * P0476 Exhaust Pressure Control Valve Range/Performance
    * P0477 Exhaust Pressure Control Valve Low
    * P0478 Exhaust Pressure Control Valve High
    * P0479 Exhaust Pressure Control Valve Intermittent
    * P0480 Cooling Fan I Control Circuit Malfunction
    * P0481 Cooling Fan 2 Control Circuit Malfunction
    * P0482 Cooling Fan 3 Control Circuit Malfunction
    * P0483 Cooling Fan Rationality Check Malfunction
    * P0484 Cooling Fan Circuit Over Current
    * P0485 Cooling Fan Power/Ground Circuit Malfunction
    DTC Codes - P0500-P0599 - Vehicle Speed Controls and Idle Control System
    * P0500 Vehicle Speed Sensor Malfunction
    * P0501 Vehicle Speed Sensor Range/Performance
    * P0502 Vehicle Speed Sensor Low Input
    * P0503 Vehicle Speed Sensor Intermittent/Erratic/High
    * P0505 Idle Control System Malfunction
    * P0506 Idle Control System RPM Lower Than Expected
    * P0507 Idle Control System RPM Higher Than Expected
    * P0510 Closed Throttle Position Switch Malfunction
    * P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
    * P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
    * P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
    * P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
    * P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
    * P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
    * P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
    * P0533 A/C Refrigerant Pressure Sensor Circuit High Input
    * P0534 Air Conditioner Refrigerant Charge Loss
    * P0550 Power Steering Pressure Sensor Circuit Malfunction
    * P0551 Power Steering Pressure Sensor Circuit Range/Performance
    * P0552 Power Steering Pressure Sensor Circuit Low Input
    * P0553 Power Steering Pressure Sensor Circuit High Input
    * P0554 Power Steering Pressure Sensor Circuit Intermittent
    * P0560 System Voltage Malfunction
    * P0561 System Voltage Unstable
    * P0562 System Voltage Low
    * P0563 System Voltage High
    * P0565 Cruise Control On Signal Malfunction
    * P0566 Cruise Control Off Signal Malfunction
    * P0567 Cruise Control Resume Signal Malfunction
    * P0568 Cruise Control Set Signal Malfunction
    * P0569 Cruise Control Coast Signal Malfunction
    * P0570 Cruise Control Accel Signal Malfunction
    * P0571 Cruise Control/Brake Switch A Circuit Malfunction
    * P0572 Cruise Control/Brake Switch A Circuit Low
    * P0573 Cruise Control/Brake Switch A Circuit High
    * P0574 Cruise Control Related Malfunction
    * P0575 Cruise Control Related Malfunction
    * P0576 Cruise Control Related Malfunction
    * P0578 Cruise Control Related Malfunction
    * P0579 Cruise Control Related Malfunction
    * P0580 Cruise Control Related Malfunction
    DTC Codes - P0600-P0699 - Computer Output Circuit
    * P0600 Serial Communication Link Malfunction
    * P0601 Internal Control Module Memory Check Sum Error
    * P0602 Control Module Programming Error
    * P0603 Internal Control Module Keep Alive Memory (KAM) Error
    * P0604 Internal Control Module Random Access Memory (RAM) Error
    * P0605 Internal Control Module Read Only Memory (ROM) Error
    * P0606 PCM Processor Fault
    * P0607 Control Module Performance
    * P0608 Control Module VSS Output "A" Malfunction
    * P0609 Control Module VSS Output "B" Malfunction
    * P0620 Generator Control Circuit Malfunction
    * P0621 Generator Lamp "L" Control Circuit Malfunction
    * P0622 Generator Field "F" Control Circuit Malfunction
    * P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
    * P0654 Engine RPM Output Circuit Malfunction
    * P0655 Engine Hot Lamp Output Control Circuit Malfunction
    * P0656 Fuel Level Output Circuit Malfunction
    DTC Codes - P0700-P0899 - Transmission
    * P0700 Transmission Control System Malfunction
    * P0701 Transmission Control System Range/Performance
    * P0702 Transmission Control System Electrical
    * P0703 Torque Converter/Brake Switch B Circuit Malfunction
    * P0704 Clutch Switch Input Circuit Malfunction
    * P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
    * P0706 Transmission Range Sensor Circuit Range/Performance
    * P0707 Transmission Range Sensor Circuit Low Input
    * P0708 Transmission Range Sensor Circuit High Input
    * P0709 Transmission Range Sensor Circuit Intermittent
    * P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
    * P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
    * P0712 Transmission Fluid Temperature Sensor Circuit Low Input
    * P0713 Transmission Fluid Temperature Sensor Circuit High Input
    * P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
    * P0715 Input/Turbine Speed Sensor Circuit Malfunction
    * P0716 Input/Turbine Speed Sensor Circuit Range/Performance
    * P0717 Input/Turbine Speed Sensor Circuit No Signal
    * P0718 Input/Turbine Speed Sensor Circuit Intermittent
    * P0719 Torque Converter/Brake Switch B Circuit Low
    * P0720 Output Speed Sensor Circuit Malfunction
    * P0721 Output Speed Sensor Range/Performance
    * P0722 Output Speed Sensor No Signal
    * P0723 Output Speed Sensor Intermittent
    * P0724 Torque Converter/Brake Switch B Circuit High
    * P0725 Engine Speed input Circuit Malfunction
    * P0726 Engine Speed Input Circuit Range/Performance
    * P0727 Engine Speed Input Circuit No Signal
    * P0728 Engine Speed Input Circuit Intermittent
    * P0730 Incorrect Gear Ratio
    * P0731 Gear I Incorrect ratio
    * P0732 Gear 2 Incorrect ratio
    * P0733 Gear 3 Incorrect ratio
    * P0734 Gear 4 Incorrect ratio
    * P0735 Gear 5 Incorrect ratio
    * P0736 Reverse incorrect gear ratio
    * P0740 Torque Converter Clutch Circuit Malfunction
    * P0741 Torque Converter Clutch Circuit Performance or Stuck Off
    * P0742 Torque Converter Clutch Circuit Stock On
    * P0743 Torque Converter Clutch Circuit Electrical
    * P0744 Torque Converter Clutch Circuit Intermittent
    * P0745 Pressure Control Solenoid Malfunction
    * P0746 Pressure Control Solenoid Performance or Stuck Off
    * P0747 Pressure Control Solenoid Stuck On
    * P0748 Pressure Control Solenoid Electrical
    * P0749 Pressure Control Solenoid Intermittent
    * P0750 Shift Solenoid A Malfunction
    * P0751 Shift Solenoid A Performance or Stuck Off
    * P0752 Shift Solenoid A Stuck On
    * P0753 Shift Solenoid A Electrical
    * P0754 Shift Solenoid A Intermittent
    * P0755 Shift Solenoid B Malfunction
    * P0756 Shift Solenoid B Performance or Stock Off
    * P0757 Shift Solenoid B Stuck On
    * P0758 Shift Solenoid B Electrical
    * P0759 Shift Solenoid B Intermittent
    * P0760 Shift Solenoid C Malfunction
    * P0761 Shift Solenoid C Performance or Stuck Off
    * P0762 Shift Solenoid C Stuck On
    * P0763 Shift Solenoid C Electrical
    * P0764 Shift Solenoid C Intermittent
    * P0765 Shift Solenoid D Malfunction
    * P0766 Shift Solenoid D Performance or Stuck Off
    * P0767 Shift Solenoid D Stuck On
    * P0768 Shift Solenoid D Electrical
    * P0769 Shift Solenoid D Intermittent
    * P0770 Shift Solenoid E Malfunction
    * P0771 Shift Solenoid E Performance or Stuck Off
    * P0772 Shift Solenoid E Stuck On
    * P0773 Shift Solenoid E Electrical
    * P0774 Shift Solenoid E Intermittent
    * P0780 Shift Malfunction
    * P0781 1-2 Shift Malfunction
    * P0782 2-3 Shift Malfunction
    * P0783 3-4 Shift Malfunction
    * P0784 4-5 Shift Malfunction
    * P0785 Shift/Timing Solenoid Malfunction
    * P0786 Shift/Timing Solenoid Range/Performance
    * P0787 Shift/Timing Solenoid Low
    * P0788 Shift/Timing Solenoid High
    * P0789 Shift/Timing Solenoid Intermittent
    * P0790 Normal/Performance Switch Circuit Malfunction
    * P0801 Reverse Inhibit Control Circuit Malfunction
    * P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
    * P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
    Sep 2010
    uk
    Audi A6
    this websit is really helpful ha.if i need to diagnostic my car,just need to get the help from there.
    thanks jamied for your sharing.
    Amy from CHINA
    Tel:8615072360818
    Jan 2011
    o4plate astra sri 2.2
    hi guys got the engine managment light on dash, it reads no camshaft censore found. but my astra sri does not have 1 built in any advise it wont shift plz help its doing my nut in.
